Hey My problem is not solved....
im including the code
test1 file
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Folder]
@="Folder"
"EditFlags"=dword:000003d2
"TileInfo"="prop:Size"
"BrowserFlags"=dword:00000008
[HKEY_CLASSES_ROOT\Folder\DefaultIcon]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,00,\
65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,33,00,00,00
[HKEY_CLASSES_ROOT\Folder\shell]
@="open"
[HKEY_CLASSES_ROOT\Folder\shell\explore]
"BrowserFlags"=dword:00000022
"ExplorerFlags"=dword:00000021
[HKEY_CLASSES_ROOT\Folder\shell\explore\command]
00,5c,00,45,00,78,00,70,00,6c,00,6f,00,72,00,65,00,72,00,2e,00,65,00,78,00,\
65,00,20,00,2f,00,65,00,2c,00,2f,00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,\
00,25,00,49,00,2c,00,25,00,4c,00,00,00
[HKEY_CLASSES_ROOT\Folder\shell\explore\ddeexec]
@="[ExploreFolder(\"%l\", %I, %S)]"
"NoActivateHandler"=""
[HKEY_CLASSES_ROOT\Folder\shell\explore\ddeexec\application]
@="Folders"
[HKEY_CLASSES_ROOT\Folder\shell\explore\ddeexec\ifexec]
[HKEY_CLASSES_ROOT\Folder\shell\explore\ddeexec\topic]
@="AppProperties"
[HKEY_CLASSES_ROOT\Folder\shell\open]
"BrowserFlags"=dword:00000010
"ExplorerFlags"=dword:00000012
[HKEY_CLASSES_ROOT\Folder\shell\open\command]
65,00,20,00,2f,00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,00,25,00,49,00,2c,\
[HKEY_CLASSES_ROOT\Folder\shell\open\ddeexec]
@="[ViewFolder(\"%l\", %I, %S)]"
[HKEY_CLASSES_ROOT\Folder\shell\open\ddeexec\application]
@="Folders"
[HKEY_CLASSES_ROOT\Folder\shell\open\ddeexec\ifexec]
[HKEY_CLASSES_ROOT\Folder\shell\open\ddeexec\topic]
@="AppProperties"
[HKEY_CLASSES_ROOT\Folder\shellex]
[HKEY_CLASSES_ROOT\Folder\shellex\ColumnHandlers]
[HKEY_CLASSES_ROOT\Folder\shellex\ColumnHandlers\{0D2E74C4-3C34-11d2-A27E-00C04FC30871}]
[HKEY_CLASSES_ROOT\Folder\shellex\ColumnHandlers\{24F14F01-7B1C-11d1-838f-0000F80461CF}]
[HKEY_CLASSES_ROOT\Folder\shellex\ColumnHandlers\{24F14F02-7B1C-11d1-838f-0000F80461CF}]
[HKEY_CLASSES_ROOT\Folder\shellex\ColumnHandlers\{66742402-F9B9-11D1-A202-0000F81FEDEE}]
[HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers]
[HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers\7-Zip]
@="{23170F69-40C1-278A-1000-000100020000}"
[HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers\BitDefender Antivirus v7]
@="{D653647D-D607-4DF6-A5B8-48D2BA195F7B}"
[HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers\WinRAR]
@="{B41DB860-8EE4-11D2-9906-E49FADC173CA}"
[HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers\WinZip]
@="{E0D79304-84BE-11CE-9641-444553540000}"
[HKEY_CLASSES_ROOT\Folder\shellex\DragDropHandlers]
[HKEY_CLASSES_ROOT\Folder\shellex\DragDropHandlers\WinRAR]
[HKEY_CLASSES_ROOT\Folder\shellex\DragDropHandlers\WinZip]
@="{E0D79305-84BE-11CE-9641-444553540000}"
[HKEY_CLASSES_ROOT\Folder\shellex\PropertySheetHandlers]
and test 2
[HKEY_CLASSES_ROOT\file]
"URL Protocol"=""
@="URL:File Protocol"
"Source Filter"="{E436EBB6-524F-11CE-9F53-0020AF0BA770}"
[HKEY_CLASSES_ROOT\file\CLSID]
@="{00000303-0000-0000-C000-000000000046}"
If you want the best, you have to vote for the best
V.I.P.U.L.:= Vigilant Individual Programmed for Ultimate Learning
