04-12-2008, 05:07 PM
Wise Old Mouse
Is this Normal Speed?
I am confused. Will kill myself or Airtel
Upload > Download
04-12-2008, 05:08 PM
Re: Is this Normal Speed?
Not normal, but possible.
Check : www.speedtest.org
04-12-2008, 10:28 PM
Wise Old Mouse
Can anyone tell what is the meaning of PING?
04-12-2008, 10:31 PM
AFK
Ping:
The TCP/IP service that lets you check to verify that you can reach another network node from your local host.
Hope thats clear............
04-12-2008, 10:34 PM
Wise Old Mouse
So what is the meaning of PING= 400ms?
04-12-2008, 11:01 PM
is NOT a PC/Mac
It means your network is reachable from other network within 400 microseconds.
05-12-2008, 06:04 AM
I also didn't knew what is ping. Thanks deb
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
05-12-2008, 03:09 PM
tHe nEw gEEk......ITian
its milliseconds i think.............???.
but thanks anyway........!!
05-12-2008, 03:22 PM
Kcots Hserf
^^me too.....thanx.
ASUS K53SM-SX0101D | Samsung Wave 525 | Canon EOS 1000D | 18-55 mm | 50mm f1.8
Registered Linux User #471793
05-12-2008, 04:09 PM
Wise Old Mouse
Mine better than ur avatar
05-12-2008, 04:18 PM
Yes, milliseconds
05-12-2008, 04:33 PM
is NOT a PC/Mac
Originally Posted by ThinkFree
Yes, milliseconds
OK, my bad. It's actually milliseconds. Actually I was doing some math problems using µs (microseconds) unit at that time, so I entered microseconds without thinking.  Sorry for any inconvenience.
05-12-2008, 04:44 PM
Not a good definition... what you are reffering to is the Ping Time! Thats the time for the round trip of a packet to go from your comp to the remote comp and back.
And your ping time isn't so good...
06-12-2008, 12:38 AM
is NOT a PC/Mac
Well, I'm not playing role of certain computer science teacher in here. Just tried to tell the basics in easy way. There is always Wikipedia and Google for the definition, descriptions et al.
07-12-2008, 07:28 PM
geek........
weel i'm in a cafe and this is the result of that internet cafe
11-12-2008, 12:58 PM
well iam also getting something screwable......!!
yesterday i got a speed of 130kB/s........on utorrent..........although my plan is 256kb/s unlimited of mtnl.....according to which the max download speed i would get is 256 kb/s..........!!!
confused in kB/s and kb/s..........!!!!
11-12-2008, 01:03 PM
Wise Old Mouse
you will never get the speed as same as your plan. remember this. as this speed includes distance between your ISP and your home. So it reduces significantly
11-12-2008, 01:08 PM
EXIT: DATA Junkyard
KB is kilobytes
Kb is kilobits
I think u're smart enug to find out which is faster among the two.
11-12-2008, 01:13 PM
#19 (permalink)
i tested my speed on speedtest.net and i get this result:
avg download speed : 1608 kb/s...
avg upload speed : 180 kb/s....
i think im getting more speed than its allowed with my plan........??
really....???is this possible .......????
11-12-2008, 01:14 PM
#20 (permalink)
Wise Old Mouse
depends.... but don't tell this to your ISP
11-12-2008, 01:25 PM
#21 (permalink)
iam not idiot bro....!!
but this is not constant.......!!!
it varies unwillingly........!!
but it means that im getting the best i could get.......!!!
tell me one more thing.........
how much max speed i can get on utorrent in kB/s (as in utorrent speed r in this unit) with 256 kbps connection and with 2 mbps connection........!!!
11-12-2008, 01:27 PM
#22 (permalink)
Wise Old Mouse
i already cleared to you it depends on the number of seeders and distance between you and them. You can't have control over them.
Better go for: http://azureus.sourceforge.net/ with auto-speed options
11-12-2008, 01:32 PM
#23 (permalink)
yar baat ye hai k agar jyada speed mile to xtra khushi hoti hai...
thats it.........!!
achha ye to batao k how can i test the max speed on utorrent.......(and otherwise ....) Is opensource s/w have max seeders n leechers .......?
well thanx mrin........
11-12-2008, 06:39 PM
#24 (permalink)
Legen-wait for it-dary!
Your internet connection. Thats your max speed. If its in kbps, divide by 8 for kBps.
thats the case usually.
Search this Thread |
