25-05-2005, 03:06 PM
Just Do It
Bittorrent Speed
This is the speed right now on bittorent while downloading music albums.
Download Rate - 2kibs, it varies from 1-4 kibs only.
Upload rate - 0kibs
Is this the normal speed ?? Or should I use Bitcomet or any other ???
25-05-2005, 05:33 PM
QA Juggler
well the speed depends completly on the Peers and there Net conn ....if u have many pears ur upload rate will b high..but it can also happen that there r 2 tasks..1 with 10 pears and other with 2 peers..and ur gettin more speed fm 2 peers as compared to 10 peers .....so just wait patiently ..and share more to get boost in speed...
8-) सारोमान :!: :!: :!:
25-05-2005, 06:01 PM
Another Brick in the Wall
It depends on the torrent and the health of the same..., even if a torrent has XX seeders and xx leechers, that does not mean we get good speeds. Also the tracker should be a public one and not private. I think admins can limit the download speed for certain IP's registered with the tracker to have limited download speeds.
I download almost 2gb a day, and i have seen a number for torrent files like that.
It does not depend on ur client dude. Use bittornado 0.3.10 for faster speeds. MY second choice: bit comet.
25-05-2005, 06:38 PM
if you have port forwarding enabled azureus takes the cake.
26-05-2005, 12:14 AM
use bitcomet . torrents become flexible n managable
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
26-05-2005, 09:09 AM
yeah bitcomet is more good
26-05-2005, 10:26 AM
Use BitTornado. Best in business.
I get speeds of 20-23 Kbits, but a part of it maybe due to DataONE
26-05-2005, 11:25 AM
ok none of the bittorrent clients you use have any effect w.r.t speeds of your downloads. That is totally dude factors which are not in the client control.
1) Your available bandwidth - If your on a 256kbps the max download speeds you can ever get is 32KB (256/8 do the math).
2) Like DrGrudge mentioned some server restrict your download speeds. Depending on your upload speed and so on.
Client features one should look at is part file downloading, seeding capabilities, debuggers, file details, file priorities and so on. Its like asking which download manager is the fastest. Given a T1 line and 2GB file all of them will download it in more or less the same time. It all depends on the added features and easy of use.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
26-05-2005, 12:11 PM
verify that ports 6881 to 6889 are open !!!
26-05-2005, 12:35 PM
hey if ports were not open then how he got even 1-4 speeds ?
26-05-2005, 12:52 PM
Just Do It
D00d tks for the reply. Is it necessary to uninstall the Bittorrent software and install bittornado ?? Also please gimme a link for the bittornado softie.
26-05-2005, 01:39 PM
^^ Can't u google?
anyways:
http://bittornado.com/download.html
Use bit tornado and see if u like it.
26-05-2005, 02:21 PM
QA Juggler
strange i get speed around 32-35KBPS for d/l + 3 KBps Upload Constantly...
26-05-2005, 11:05 PM
no it aint necessary . u can install bittornado n make it as the default program 2 open torrent files .
d00d , thats easy , aint it ??
27-05-2005, 12:09 PM
bittornado is best
Search this Thread |
