Old 04-09-2004, 06:25 PM   #1 (permalink)
Default Buying my next graphics card
Hello everyone. I want help from you to buy my next graphics card.I hve 8-10k to spare and just don't talk about stretching the budget.[/quote]
SatishSays.com
twitter.com/satishsays
devilhead_satish is offline
Old 04-09-2004, 07:12 PM   #2 (permalink)
that range u ought to go fer the 5700LE or the 9600non-pro..
both r around 7.5k...
or get the 9600XT fer 11k-ish....
delhibhai1000 is offline
Old 04-09-2004, 07:20 PM   #3 (permalink)
You can get a Club 3d9600pro for 8.5k. The fx5700 pure version at 7k. My choice wud be the 9600pro. Just so you know the Powercolor 9600XT cost 11595/-.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 04-09-2004, 09:05 PM   #4 (permalink)
9600pro anytime.
nikhilesh is offline
Old 04-09-2004, 09:13 PM   #5 (permalink)
Nvidia GeForce FX 5700.
Simple things are to simple too understand.
Prashray is offline
Old 04-09-2004, 09:43 PM   #6 (permalink)
yo...why do u recomend the nvidia GeForce Fx 57oo....i'm jus interessted cos i'm lookin for a card as well..and everyone says 9600
Nitin Garg...
madman123 is offline
Old 05-09-2004, 12:31 AM   #7 (permalink)
gxsaurav
Posts: n/a
FX5700 from Gigabyte comes for Rs 9,200
Old 05-09-2004, 10:28 AM   #8 (permalink)
Just look for the "THE graphics cards LIST" post.
anidex is offline
Old 07-09-2004, 11:09 AM   #9 (permalink)
Posts: n/a
ENNYAH GEFORCE FX5700 128MB DDR 256 BIT -RS 7900/-
PERFORMS BETTER THAN RADEON 9600
Old 07-09-2004, 01:27 PM   #10 (permalink)
I believe u got this frm techtree.........
Old 11-09-2004, 08:56 PM   #11 (permalink)
Enyah is definitely a 128 bit version card and is a 5700LE. I would'nt touch a unknown brand like Enyah with a barge pole.
9600XT is much superior in performance compared to 9600PRO. I would recommend a 9600XT if you can up your budget just a little
ganesh8 is offline
Old 11-09-2004, 09:32 PM   #12 (permalink)
No the Ennyah thats @ 7k is a pure version of the Fx5700 @ 425/550. The LE crap is clocked badly @ 225/400.
