Old 29-11-2008, 09:10 PM   #1 (permalink)
Question HELP:please suggest new M.B+Proc under 10k
Hi Everybody,
i want upgrade my old rig..please suggest me a proc+M.B(10k)... intel preferred.. i will buy ram ,HDD separate..right now i dont want 2 buy a graphics card...
1)please recommend me a Motherboard with good graphic support(5-6.5k)???
2)can i play all upcoming games(G.T.A -4) with onboard gpu?
at least low res??
3) which chipset is better...intel43/nvidia nForce 790i/gForce 9400??
[IMG]file:///C:/DOCUME%7E1/AUTHEN%7E1/LOCALS%7E1/Temp/moz-screenshot-4.jpg[/IMG]
please helpppp... i am looking for uu ]
dips_view is offline
Old 29-11-2008, 09:36 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: HELP:please suggest new M.B+Proc under 10k
Please tell me all ur wants
then the total budget
And i'll try to help out
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 29-11-2008, 10:20 PM   #3 (permalink)
i am targeting Intel core 2 duo series(5-6k price range) with a descent Motherboard with onboard graphics (asus,msi, gigabyte) (5-6k) range...
i am not sure abt chipsets which will be better?? (G43from intel/nvidia gforce/nforce)!!!
and total budget around (16-17k) with ram+HDD+M.B+proc+P.S.U
Old 29-11-2008, 10:41 PM   #4 (permalink)
damnbadman666
damngoodman999's Avatar
At this budget & if u searching for on board graphics means in INTEL u will never get below 10k
In AMD u can get !!!
In AMD 790 & 780 chipset can play GTA-4
Last edited by damngoodman999; 29-11-2008 at 10:41 PM. Reason: Automerged Doublepost
damngoodman999 is offline
Old 30-11-2008, 12:42 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
I will suggest this:
E7200 @ 5.4k
OR
E5200 @ 4.3k
Gigabyte G31 @ 2.8k
HD4650 @ 4.8k
OR
9500GT @ 3.7k
Total= 10.8k-13k
About me:
Old 30-11-2008, 02:54 PM   #6 (permalink)
damnbadman666
E7200 @ 5.4k
OR
E5200 @ 4.3k
Gigabyte G31 @ 2.8k
HD4650 @ 4.8k
OR
9500GT @ 3.7k
Total= 10.8k-13k
Great i forgot about this ! go for this config this is the only INTEL config u can choose
Old 30-11-2008, 07:17 PM   #7 (permalink)
thanks guys........
thanks 4 evrythinggg...
Suggest mobo + proc + ram for 4k hurricane25 Hardware Q&A 7 03-09-2008 12:41 AM
Proc Pin Broken... Geeks101 Hardware Q&A 6 25-12-2006 09:22 PM
