Old 04-09-2004, 06:00 PM   #1 (permalink)
nipun_the_gr8
Posts: n/a
Default RW - CD
Hi ! i have a sony cd - rw.It says that it is 1x - 4x compatible.Plz tell me that will i be able to burn my data on the disc usin' 48x speed ??? and also plz tell me the no. of times i can use the cd for burnin' purposes.
Old 04-09-2004, 07:12 PM   #2 (permalink)
GameAddict's Avatar
Default No
Hi,
If it is 1x-4x compatible, it can support burning at higher rates.I have a 8x and I CAN burn it at 10x, but no more. Try a bit highre setting and let me know.It is really frustrating when your writer supports 24x burning but CD-RW is limited to just 16x
Bye!
GA
GameAddict is offline
Old 04-09-2004, 07:14 PM   #3 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: RW - CD
Hmmm...
Well CD-RW's use phase changin recordin layer to record data unlike the conventional dye's like cyanine/Azo etc used by CDR's.
The higher the burn speed the more the laser power...The phase change alloy(CD-RW's) used is very sensitive to temperature hence though we can burn CDR's at 52X speed while we r limited to say 32X in CDRW's
Most newer CD-RW's use a better phase changing material thus they r able to support higher burn speeds like 24X or 32X but their use is restricted to the speed of the burner
Newer burners can burn CD-RW's is max speed of 32X.. How ever 32X CDRW are rarely found while their 24X counterparts are more commonly available while their 10X counter parts being very very common.
Now the CDRW disk u have is a 4X CDRW thus supports max speed of 4X burnin...so its impossible for u to burn it at 48X...
Well I have a old Samsung 10X CDRW which I must have burned abt say 400+ times(wit me... last 7 months) and there has'nt been one occasion wher i hav encountered data corruption (touchwood)
When formatin CDRW's always quick format instead of full format unless u work for FBI pr KGB...
Hope this helps....
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 04-09-2004, 09:24 PM   #4 (permalink)
24x cdrw.... gosh.. i need it desparately.. .. my 10x cdrw is well.. kind of almost screwed.. but hey how times can you burn and re-burn(if you can call that) the cdrw... i have burned it for 563 times now in the last 9 months.... and ya i got a data corruption error a few days ago.. but not after that.. i have burned the disc around 12times after that... so is thereany need for a new cdrw.. or should i use it right till its death hehehe.. or was it just a once in a blue moon thingy,.
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 05-09-2004, 12:01 PM   #5 (permalink)
JAK
What the Heck !
JAK's Avatar
well if it is scratchless and u havent exposed it too much to direct sunlight..
u'll be able to use it for another 300+ burns. Most companies claim 1000 burns(under standard test conditions) so if u can emulate those standard test conditions..lol.. then u'll be able 2 squeeze out those 1000 burns...
as for the data corruption maybe its ageing of the CDRW or maybe the CD was a lil dirty when burnt or maybe the burner lens was dirty..
Since u hav mentioned that this thingy hasn't happened again..u have a good chance that the CDRW u have will last..hopefully
hope this Helps...
JAK is offline
Old 05-09-2004, 12:24 PM   #6 (permalink)
dude can you also chk this topic please
http://www.thinkdigit.com/forum/viewtopic.php?t=6602
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 07-09-2004, 11:07 AM   #7 (permalink)
nipun_the_gr8
Posts: n/a
Thankx every1 & JAK, i don't wrk for FBI or KGB
Old 07-09-2004, 06:20 PM   #8 (permalink)
abhishekkulkarni's Avatar
Wow how do ya know that u burned it 563 times ? lol
May the source be with you ..
abhishekkulkarni is offline
Old 07-09-2004, 06:41 PM   #9 (permalink)
GameAddict's Avatar
Default Found any CD-RW higher then 16x?
Hi,
16x is the highest in CD-RW(comes with ASUS CD-RW, brand is Mitsubishi), I could find. If somebody has found CD-RW of greater speed, please let me know.
GA
Old 07-09-2004, 07:37 PM   #10 (permalink)
busyanuj's Avatar
Default Reply: RW - CD
yeah 8)
busyanuj is offline
Old 07-09-2004, 07:42 PM   #11 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: Found any CD-RW higher then 16x?
Originally Posted by GameAddict
Hi,
GA
Ahem....
I got a 24X CDRW with my LiteOn 52x32x52x...
JAK is offline
Old 07-09-2004, 08:25 PM   #12 (permalink)
JAK why do u always write with blue and finsh your line with this
She moves like she dont care...smooth as silk cool as air..!
superwiz is offline
