Old 24-05-2005, 04:05 PM   #1 (permalink)
Default Cooling Solutions & Cabinets
Ok Ppl
This is one topic I have to discuss
What r the cheap solutions available ?
Assume I have a AMD 3200+ and a big cabinet ( place to hang to extra fans )
Those Rs. 100 fans which just have a powersupply.. Do they help ?? Is putting 2 of them intelligence ?? one to suck in air and other to suck out air ??
Or should I put one expensive fan ??
I have never explored this field so dont know much options.. Plz dont suggest water cooling as i am aware of the hazards i can create
Also can some1 suggest a cabinet with space and side transparent ?? some jazzy cheap solution.. No Antec LAnboy plz.. out of my budget
I\'M BACK
khandu is offline
Old 24-05-2005, 04:46 PM   #2 (permalink)
rohanbee's Avatar
Well you have to make sure you study the inside of your cabinet to see the air-circulation pattern. You dont want to place the inlet and outlet of the air too close otherwise there might be no air-circulation.
Sometimes i big fan might also do the trick provided it is placed at the right spot.
Quote by Garfield'
rohanbee is offline
Old 25-05-2005, 03:16 PM   #3 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Hi khandu, Those 100K fans are just for name sake. They have very low rpm and cfm rating. Go for a branded fan with speed control. They may cost around Rs. 400 but they r woth it. Just 2 of them ( front intake and rear exhaust) will do a fine job.
As for pc cases visit http://zebronics.net for some snazzy and cheap casings with side windows and fans
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 25-05-2005, 05:29 PM   #4 (permalink)
rohanbee's Avatar
Yeah actually you are right those 100 bucks fans are just that s****y. im going to malaysia for some work. Will look for some cooling solution there.
Quote by Garfield'
rohanbee is offline
Old 25-05-2005, 05:40 PM   #5 (permalink)
zebronics looks kool
any mumbai contact number plz ??
I\'M BACK
khandu is offline
