Old 25-11-2008, 06:26 PM   #1 (permalink)
macaddict
gauravsuneja's Avatar
Cool help urgently
my pc when it starts for the first time i shows white pinkish screen with some colored vertical lines .there is no beep other than the default beep .when i take out the monitor cable attached to the cpu and then insert then it comes to life and shows bios screen .previously it was happening even if i shut down the pc properly its shows as if i has gone into hibernation and show something only when it reaches welcome screen
www.drgauravsuneja.blogspot.com
An Apple a day keeps virus away
gauravsuneja is offline
Old 25-11-2008, 07:51 PM   #2 (permalink)
Ishan's Avatar
Default Re: help urgently
before some time I had some same sort of screen colour problem in my Desktop...but i didnt tried removing cable and all...instead changed RAM and Problem Solved...ur case might be different...dunno
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 27-11-2008, 05:11 PM   #3 (permalink)
macaddict
any other suggestion?
Old 28-11-2008, 09:40 PM   #4 (permalink)
anzaan's Avatar
i culd be RAM or loose wires. reconnect all the wires inside cabinet n the monitor wire firmly
d a m n ! !
anzaan is offline
My New Rig:Help REQ Urgently!!!!!!!!! capri435 Hardware Q&A 12 29-04-2006 02:27 PM
Help Urgently hitman_never_dies QnA (read only) 1 11-03-2006 06:28 PM
PLZ HELP!!! I NEED RD RAM URGENTLY. iwant2breakfree Hardware Q&A 3 14-01-2006 01:22 PM
