Old 23-11-2008, 08:59 PM   #1 (permalink)
rook!e's Avatar
Question MAC OS X and VM
I'v three question:
1.My brother brought MAC OS x for his MAC book,Now i want to use it in my Assembled pc [MB:Asus P5KPLVM ; RAM:2GB ;HDD:250 GB] through VM. can i use it?
2.iF thelive cd of MAC OS X possible?
3.i used live cd FC4 through VM,no problem.I want to use bootable Mandriva through VM.
IS it possible??
plzz ans.
rook!e is offline
Old 24-11-2008, 12:45 AM   #2 (permalink)
naggregate's Avatar
Default Re: MAC OS X and VM
Originally Posted by rook!e View Post
I'v three question:
IS it possible??
plzz ans.
1. As far as I know, you cannot run OSX on any VM. You can however take a look at the OS X86 project website to see how you can install OSX on a regular PC. You could alternatively purchase EFIX, a small USB device that allows you to install OSX on ANY machine.
2. Not that I know of.
3. You have to install it just as you would install it on your hard drive.
Hello! I am the Internet!
naggregate is offline
Old 24-11-2008, 12:49 AM   #3 (permalink)
damnbadman666
damngoodman999's Avatar
u can use TIGER mac ..... no prob....... with the intel chipset u can easily install
damngoodman999 is offline
Old 24-11-2008, 01:38 AM   #4 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: MAC OS X and VM
I'v three question:
IS it possible??
plzz ans.
1. You can run Mac OS X in VMware, no problem with that.
2. There is a project on Mac OS X Live DVD, but I am not sure if such stuff is allowed to discuss here.
3. Bootable Mandriva in VM would run fine without a hitch.
Since you have an AMD processor, you might face some problem running a hackintosh machine. But AMD support is constantly improving and quite stable now, you can try specific versions meant for AMD processors only. BTW don't try EFI-X, it is hardly available in India and quite expensive too. There is other ways to install Mac OS X into a PC just using some softwares and tweaking the PC a little.
MODs, I'm not sure if I am doing something wrong here, please delete the post if I did.
debsuvra is offline
