Re: UPS vs Inverter
You can use a inverter to power your lights, fans, etc, and your comp too (if it supports comp)... but the main problem is that if you switch some appliance on, while your comp is running, chances are that you may face a reboot. Also, inverters dont normally filter power supply... so your comp will be at risk of power vagaries.
What I have done is, use both in series. But if you do that keep in mind that the inverter output has to be acceptable to the UPS (else load will never transfer to the inverter, when power fails). This happens mainly because not all inverters give sine wave output...
