Old 22-11-2008, 10:07 AM   #1 (permalink)
Question Zone alarm too slow!
I have zone alarm 7 pro..............but it makes my PC startup and shutdown very slow.......I cant shut it down as I am constantly on a network........any help??
visit:
http://skiewpoint.blogspot.com
http://aestheticblasphemy.blogspot.com
anshul is offline
Old 22-11-2008, 12:02 PM   #2 (permalink)
Default Re: Zone alarm too slow!
Don't use it....
Try Comodo, it is atleast faster than this and it is free.
ico is offline
Old 22-11-2008, 04:30 PM   #3 (permalink)
I have used it and find it annoying...as it asks for each and every step even if I opt for remember my settings..............
visit:
anshul is offline
Old 22-11-2008, 05:10 PM   #4 (permalink)
"Aal Izz Well"
Krazzy Warrior's Avatar
Zone Alarm just rocks for me...but if u facing prob remove it and install any other..
http://twitter.com/krazzywarrior
Krazzy Warrior is offline
Old 22-11-2008, 06:42 PM   #5 (permalink)
sidewinder's Avatar
dont use defence+ ..
Bombina rocks
sidewinder is offline
Old 22-11-2008, 07:35 PM   #6 (permalink)
I have done it many times(uninstall) but doesnt help..............
visit:
anshul is offline
Old 23-11-2008, 12:32 AM   #7 (permalink)
Zone alarm is supposed to be bloatware. I just stay far away from all bloatware. These Firewall/Antivirus/Spyware/etc, developers forget that PCs are ment to do other stuff... not just run security software!!!
One of the lightest firewalls (and safest!) I'v used was Looknstop. But it refused to work with dataone. Tried lots of things, including asking the developer. Finally just gave up.
Raccoon is online now
Old 23-11-2008, 07:23 PM   #8 (permalink)
afonofa's Avatar
Lightbulb Re: Zone alarm too slow!
Upgrade to ZoneAlarm Pro v8.0.059.000. It shuts down and starts up faster than ZAP v7. If you are using any other anti-spyware for realtime scanning then you can turn off ZAP's anti-spyware, which will speed up ZAP and your comp. You can also turn off ZAP's anti-spyware if you are using an anti-virus which is good at detecting spyware(like Kaspersky AV).
Depending on whether your ZAP v7 license is purchased or pirated, it may or may not work with ZAP v8.
afonofa is offline
Old 23-11-2008, 07:25 PM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
Here: http://www.techsupportalert.com/best-free-firewall.htm
- MrinTech :)
mrintech is offline
Zone Alarm godsownman QnA (read only) 21 08-10-2005 10:50 PM
xp,zone alarm or me? mariner Software Q&A 12 08-09-2005 01:59 PM
Zone Alarm! cancer10 QnA (read only) 20 17-07-2005 01:55 PM
Zone Alarm pro help ! ! ! ax3 QnA (read only) 4 08-04-2005 11:28 AM
Zone alarm rahulbpatil QnA (read only) 3 08-09-2004 03:58 PM
- by gforz
- by soumya
