Old 19-11-2008, 04:49 PM   #1 (permalink)
choudang's Avatar
Default Removing Entry without Uninstalling
dear all,
I don't know this is possible or not.. but just seeking you thots about it.
As i have using portable apps for a few applications, now i have decided to use the full version on my official laptop. but as we have certain policies .. i hv installed photoshop on my porable HDD and its working fine. but entry has been made in ADD REMOVE programs.
our Local IT says that they don't have any issue and i can use it, but they can't remove the entry from A&R progaram list and it will be displayed in their BH report and BH policy does not approve that.
So, can we remove that entry by removing from registry, if so, will it working fine, and how to do it.
For every action, there is an equal and opposite criticism.
choudang is offline
Old 19-11-2008, 05:09 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Removing Entry without Uninstalling
Yes, you can remove entry from Add/Remove Programs
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Uninstall
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 19-11-2008, 06:50 PM   #3 (permalink)
choudang's Avatar
thanks buddy.......
but programs will works properly or not
choudang is offline
Old 19-11-2008, 07:02 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
1. CCleaner
2. RevoUninstaller
Both work
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 19-11-2008, 07:17 PM   #5 (permalink)
choudang's Avatar
hats off
choudang is offline
Old 20-11-2008, 11:19 AM   #6 (permalink)
The Boy Who Lived
hjpotter92's Avatar
CCleaner and REvo are used to uninstall.
Core i7 920 @ 2.67 GHz
Intel DX58SO
3 GB DDR3 1600 MHz RAM
nVIDIA GeForce 9600 GS
Razer Arctosa + Abyssus
Please help: http://www.thinkdigit.com/forum/prog...p-windows.html
hjpotter92 is offline
Old 20-11-2008, 04:28 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
If u hav used them properly
They allow u to remove from registry.
About me:
Old 20-11-2008, 05:32 PM   #8 (permalink)
The Boy Who Lived
hjpotter92's Avatar
At least Revo does only if you uninstall the program.
Intel DX58SO
Old 20-11-2008, 06:15 PM   #9 (permalink)
choudang's Avatar
m not uninstalling dear .... only removing the entry .......
anyway .. thanks and hats off to all of you
choudang is offline
Old 21-11-2008, 03:59 PM   #10 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Even REVO has the option to remove from registry only
About me:
Removing MS office 2003 entry from Add/Remove Panel psnegi26136 Software Q&A 10 02-05-2007 10:38 PM
Uninstalling OS....??? Pragadheesh QnA (read only) 2 11-11-2006 09:06 PM
Removing the entry from explorer uvg_don Software Q&A 1 30-03-2006 07:02 AM
Uninstalling Win XP cvvikram Software Q&A 7 10-06-2005 11:46 AM
uninstalling OS?? mario_pant QnA (read only) 6 14-04-2005 10:41 PM
- by gforz
- by soumya
