Old 23-05-2005, 11:53 PM   #1 (permalink)
kumarmohit's Avatar
Default RAM Speed
Hi can anyone tell me if I install a 256 MB 266MHz RAM Module // to a 128 MB 133MHz Module Will there be any problems due to speed differences and what's with the RAM Latency etc
kumarmohit is offline
Old 24-05-2005, 12:09 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
i dont think there will be any problems but the 256 mb module will also work at 133 mhz. rite guyz ? btw which mobo are u using ? check its manual and stuff also.
mohit is offline
Old 24-05-2005, 12:55 AM   #3 (permalink)
133 mhz ddr runs at 266 so it should work fine with ur 256 module
Happy Computing
krishnathelord is offline
Old 24-05-2005, 05:09 PM   #4 (permalink)
rohanbee's Avatar
According to me it will not work. I dont think you can pair ram of two different sizes. Bus speeds, latencies can be different but not the configuration.
Latency is basically the timmings of the ram. This is the time which the ram will take at different speeds to preform read/write tasks.
Quote by Garfield'
rohanbee is offline
Old 24-05-2005, 05:58 PM   #5 (permalink)
rohanbee...it will work fine. RAM sizes/frequencies/latencies can all be different and it will work fine. And yes I can combine different brands and so on. Onl thing you cannot do is combine a DDR RAM with a SDRAM or a DDR2 RAM (altho I think I have seen a mobo which supports both DDR and DDR2 I think).
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 24-05-2005, 06:09 PM   #6 (permalink)
I am agreed with Icecoolz. But one doubt I have, for two ram with different speeds, at which speed will the system run actually?
sumitava_b is offline
Old 24-05-2005, 06:33 PM   #7 (permalink)
the RAM will run at the lower speeds of the two.
AMD 64 3500+ Venice
icecoolz is offline
Old 25-05-2005, 02:00 PM   #8 (permalink)
rohanbee's Avatar
I think asus and msi both make those mobo's. I know theoretically it is said that they work. But there are crashes and problems in practical usage. Then again if you are lucky there might be none. So lets all just be Lucky!!
Quote by Garfield'
rohanbee is offline
Old 25-05-2005, 05:54 PM   #9 (permalink)
icecoolz and rohanbee , Athlons does not have support for DDR 2 as of now , rumors says that they are directly going to XDR or DDR3 which is alredy posted here - http://www.thinkdigit.com/forum/viewtopic.php?t=20997
Also u need more pins on the processor to support DDR2 .
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 25-05-2005, 06:08 PM   #10 (permalink)
hmm...then I must have seen an intel board which supports both....oh well DD3 is the future neways. But right now I am happy with my PC
AMD 64 3500+ Venice
icecoolz is offline
Old 25-05-2005, 06:08 PM   #11 (permalink)
Location: heaven doesn't want me and hell's afraid i'll take over
guys could u help me??
is there a seperate type of sdram for p4's if so how do identify it??and how do u find out the cas latency??
sandeeprao is offline
Old 25-05-2005, 07:39 PM   #12 (permalink)
t3h g04t
teknoPhobia's Avatar
SDRAM and DDR do not... repeat do not work 2gether even if the board has slots for both... you can use either...typical CAS latencies at max speed for common RAM types is 3 for SDRAM and 2.5 for DDR, 4 for DDR2. those supporting lower latencies are usually boldly advertised as "high speed" RAM. hynix chips...most common...DDR are 2.5 at max speed and 2 for the next lowest. U can use most coomon bm progs lyk sandra to find out supported speeds/latencies. You have to use identical ram types only if you are using dual channel config
technologically challenged.
teknoPhobia is offline
Old 26-05-2005, 03:27 PM   #13 (permalink)
rohanbee's Avatar
DDR3 i dont think intel has any plans yet. DDR2 also still in its infancy yet wonder when ddr3 will actually come ahead. Already seeing this type of memory in graphics cards
Quote by Garfield'
rohanbee is offline
Old 26-05-2005, 05:26 PM   #14 (permalink)
dinesh_singh
Posts: n/a
the point is.....
you can always install two sticks of diff memory size like 128mb \and 256 mb
but they should be at same speed....or problem will definately arise
i had a same problem....
Old 28-05-2005, 12:39 PM   #15 (permalink)
rohanbee's Avatar
No that is not correct. SPeeds can vary that will lead to the mobo running the ram at the speed of the slower one.
Quote by Garfield'
rohanbee is offline
