Old 17-11-2008, 07:42 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Question HELP !!! gona buy DVD Writer
i called my h/w dealer to buy a DVD writer.
he was asking me my mobo config. whether i v 915 945 ... blah blah
and was asking me aapko ID wala chahiye ki sada vala .. i m clueless as to what he is talking abt?
he says DVD writer is diff for diff motherboards.
i plan to use this DVD writer for my
Intel Pentium D 102GGC2 AND my other PC PIII 810E
plz help ....
mekalodu
iinfi is offline
Old 17-11-2008, 08:11 PM   #2 (permalink)
din
Tribal Boy
din's Avatar
Default Re: HELP !!! gona buy DVD Writer
May be he meant IDE / SATA Writer ?
din is offline
Old 17-11-2008, 08:16 PM   #3 (permalink)
mekalodu
iinfi's Avatar
may b man .... i dunno ... cud not hear his voice clearly over the line.. wats the difference.
will i be able to use it on both my PCs?
mekalodu
iinfi is offline
Old 17-11-2008, 08:27 PM   #4 (permalink)
If your mobo has SATA port, it might be a better idea to go for SATA DVD drive. However, you'll likely not notice any difference in performance even if you go for IDE DVD drive. But for future compatibality (if relevant to you) its better to go for SATA.
If both your comps have SATA ports, then only go for SATA drive. Else IDE is the only option for you. I dont think your PIII will have a SATA port.
Raccoon is online now
Old 17-11-2008, 08:32 PM   #5 (permalink)
mekalodu
iinfi's Avatar
oh.... i initially didnt understand wat it meant ...thanks for the clarification.
the older one doesnt have SATA. i will buy the IDE one ... Rs. 1250 is wat he quoted.
thanks
mekalodu
iinfi is offline
Old 17-11-2008, 11:46 PM   #6 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
yup, go for IDE, as even if the next gen mobos didn;'t hv a IDE, we ppl wud jus buy a new Optical drive, "kitne paise hi lagte hain" new optical drives ke liye yar.
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 18-11-2008, 12:05 AM   #7 (permalink)
I belive you can get IDE to SATA converters... and possibly vice versa too. Then you could use it on both comps.
As for prices, LG is going for about 1,050 to 1,100 and Moser Baer LiteOn for 1,200 in Poona. I'd think Bombay should be cheaper...
Old 18-11-2008, 12:49 AM   #8 (permalink)
mekalodu
iinfi's Avatar
bought it .... the IDE one ... working ... so far so good... thanks all
mekalodu
iinfi is offline
Old 19-11-2008, 08:07 PM   #9 (permalink)
plz help ....
How much did you paid for it?
mar4ela is offline
Old 19-11-2008, 08:30 PM   #10 (permalink)
din
Tribal Boy
din's Avatar
@Raccoon
From my experience, the IDE to SATA / SATA to IDE adapters / converters are not reliable. They may work, but not guaranteed.
din is offline
Old 19-11-2008, 09:44 PM   #11 (permalink)
mekalodu
iinfi's Avatar
Rs. 1250/- Samsumg IDE one
mekalodu
iinfi is offline
Old 19-11-2008, 11:39 PM   #12 (permalink)
Originally Posted by din View Post
@Raccoon
Is it? Never used one... so wont comment.
Thats a li'l higher price you paid... esp. for a Samsung!!! You could have gotten an LG for Rs. 1,100 max!
Old 19-11-2008, 11:42 PM   #13 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^yeah, correct. Change ur h/w dealer man.
Blogging at:
Technostarry
saqib_khan is offline
Old 19-11-2008, 11:45 PM   #14 (permalink)
mekalodu
iinfi's Avatar
its slightly costlier in panvel here... if i goto vashi i cud v got it for Rs. 1100/-
but buying it near my house means, commuting expenses saved, any other needless expenditure saved, and by going to vashi chances of bumping into any female friends of mine and taking them out for a snack increase.
so this is cheaper.
added:
yea.. i think i sud change the h/w dealer.... i goto this fellow coz he normally replaces stuff if it is faulty
mekalodu
iinfi is offline
Old 20-11-2008, 12:00 AM   #15 (permalink)
Gosh, never imagined cost of gfs getting factored into cost of acquiring hardware...
DVD writer damn slow..I got IMATION dvd writer.. roonie Hardware Q&A 9 09-01-2008 08:05 PM
Gona buy a TV..suggest me guys. naveen_reloaded QnA (read only) 25 05-01-2008 11:08 PM
got a new dvd writer Samsung Super WriteMaster 18x DVD Writer xbonez Hardware Q&A 7 14-08-2007 02:10 PM
Gona Get K700i reddick QnA (read only) 46 23-01-2005 10:37 PM
- by gforz
- by soumya
