Old 23-05-2005, 07:45 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default can i uninstall msn messenger ?
guys, just tell me one thing.
i dont use msn messenger. i have also disabled it from its own startup setting, plus also from a few other utilities. but the darned thing just appears once in a while in my system tray when on the net, saying its up, b'coz i m using so-and so.
can i just go to the 'add-remove programs' and uninstall it ?
it wont affect my WinXP/SP2 normal operation in any way would it ?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 23-05-2005, 08:11 PM   #2 (permalink)
Just uninstall it if you don't want it. It won't cause any problems.
paraman is offline
Old 23-05-2005, 08:33 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
You can uninstall from Windowns components ....go to add remove select Windows components and uncheck MSN from it or if u want a proff tool then try MSN Uninstaller
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 23-05-2005, 09:03 PM   #4 (permalink)
expertno.1's Avatar
you can also remove it by unchecking in the startup section of msconfig
expertno.1 is offline
Old 23-05-2005, 10:59 PM   #5 (permalink)
sidewinder's Avatar
it reappears coz it associates with ie nd oe.Uninstall it frm add remove prog.There shgd be no prob
Bombina rocks
sidewinder is offline
Old 24-05-2005, 01:23 PM   #6 (permalink)
Just Do It
Charley's Avatar
Originally Posted by saROMan
MSN Uninstaller[/url]
Isn't Quarterdeck or Norton softies any better ? ?/
Charley is offline
Old 24-05-2005, 07:05 PM   #7 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Read this
http://www.petri.co.il/uninstall_win...windows_xp.htm
navjotjsingh is offline
Old 25-05-2005, 08:58 AM   #8 (permalink)
anandk's Avatar
fianlly uninstalled msn msngr. thanx !
Microsoft® MVP
anandk is offline
Old 25-05-2005, 10:53 AM   #9 (permalink)
i doubt u would have faced NE problems !!!
cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
- by gforz
- by soumya
