My desktop PC(Pentium 3, 256MB memory, 3.2GB free space in C) hangs exactly after 15 minutes after the booting.
the time depends upon the application you run, for example if I run photoshop, it gets stuck after 7 minutes.
Please update me with the root cause for this problem and the possible solution.
Thanks.
Add some more Ram to your pc and check whether your power supply is working properly. It might be a virus as well. Try to scan your computer with a updated antivirus.
Which Version of Photoshop are you running? It might be too heavy on your system.Try upgrading your RAM and Processor.Or, you can try older versions like 6.0 Which will run fine on your config.
Not exactly like photoshop... any high - end application.. makes my PC to hang.. after few minutes
