Guys i'm getting the following mssg on windows startup.
Win networking (TITLE)
Unable 2 load dynamic link library
the sys can't find the file specified
msnp32.dll
Some or all of the following features aren't available:
Microsoft network.
Plz help me what shud i do?
if you are using win98 ? check if you have a file name msnet32.dll on your system in the c:\windows\system directory?
If you don't have msnet32.dll on your system then extract it from your W98 CD.
Start>Run key in SFC and press enter. Click on the bottom bullet titled "Extract a system file" and key in msnet32.dll in the box, insert your W98 CD and click Start. Enter d:\win98\ in the "Restore From" box and enter c:\windows\system in the "Save File In" box. Then click OK. After the extract is done restart Windows.
Also check for the existance of these other files and extract them in the same way if you don't have them on your harddrive dfs.vxd, vnetsup.vxd and vredir.vxd.
