14-11-2008, 09:05 PM
Unable to Delete a Porn File on Desktop
I am Very Sad, a porn File on Mine Desktop . I am Unable to Delete this File!! As Mine Computer Is Family PC Mine Brother & Sister Use to Open, So I am Really Worried what happen when they see this File name?
Here Is Screenshot:
Please Guys Help Me its urgent
I also Used Delete Doctor 2.2, But it also Not Working
See Screenshot:
i used All method Even : Delete file on System Restart
please help me
Reason: Automerged Doublepost
14-11-2008, 09:11 PM
Wise Old Mouse
Re: Unable to Delete a Porn File on Desktop
First of all stop navigating DBBlog... you know what i mean.... open command prompt and delete it....
c:\>complete file location> del file name.extension
14-11-2008, 09:12 PM
Here is File Properties...Screenshot:
14-11-2008, 09:13 PM
Wise Old Mouse
it can't be deleted because it is being used by some other program... use CMD to delete it....
and give screenshots as thumbnails
14-11-2008, 09:19 PM
restart the system and then try
if it doesn't work boot in safe mode ..it will surely work
14-11-2008, 09:24 PM
i used CMD Method
See Screenshot:
adi007
i just used Safemode there also same problem :Cannot Delete File : Cannot Read from Source File, Coming
please tell me any otherway..please
14-11-2008, 09:28 PM
Wise Old Mouse
simply make the file hidden after copying it to some other folder or rename it. it win't play as it is 0 bytes....
14-11-2008, 09:38 PM
mrintech, Its unable to Rename or Move ..See Screenshot...
please Help
14-11-2008, 09:40 PM
Dreamweaver
temp solution: hide it
14-11-2008, 09:48 PM
dá ûnrêäl Kiñg
try file unlocker,unlock the file n then delete
http://ccollomb.free.fr/unlocker/
My Stomach pains:D:D
http://tinyurl.com/32jj4m
14-11-2008, 09:50 PM
Commander in Chief
Use Unlocker?
You're probably infected.
Harsh J
www.harshj.com
14-11-2008, 10:08 PM
Wise Old Mouse
14-11-2008, 10:34 PM
I think the file is removed but the file name is not deleted(dunno what it is exactly called)...
run checkdisk..
That is chkdsk/f
it will ask whether to check at next restart press yes ... and then try
14-11-2008, 10:44 PM
The Devil's Advocate
http://beingmanan.com
14-11-2008, 10:46 PM
Unlocker your best choice. I'm 110% sure that it will get rid of it.
ADViCE:-Stay away from 18+ sites more that 80% of them are fake.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
14-11-2008, 11:11 PM
do a checkdisk... it is definitely some residue after the file has been deleted.. restart ur pc... even after that it doesnot work then use Ubuntu Live CD/DVD and navigate to ur windows desktop through c:\documents and settings\......\.... if u r able to see that file... u will definitely be able to delete it...
TechExplorer.in
15-11-2008, 02:05 AM
AFK
Originally Posted by iMav
You can say that again.
I remember that hugely popular thread that was finally locked due to obvious reasons
15-11-2008, 02:35 AM
use live cd and then just delete it if nothing works.
jajajaja and next time before doing any thing mature be a mature geek.
15-11-2008, 10:43 AM
#19 (permalink)
15-11-2008, 11:49 AM
#20 (permalink)
In the Zone
if nothing works just create another user account and delete the current one............
don't forget to take backup of all those stuff on ur current desktop before deleting the account
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi Sony Ericsson Xperia Arc S (Gloss Black)
15-11-2008, 12:49 PM
#21 (permalink)
The Boy Who Lived
I will say yes to 13lu. That will surely get your job done.
15-11-2008, 02:18 PM
#22 (permalink)
EXIT: DATA Junkyard
Like bieng *&^ to save p*** on Desktop directly, not even renaming the file b'fore saving!
And on a family PC holy &^*^
15-11-2008, 04:07 PM
#23 (permalink)
TheSaint
Method 1 (best):
Boot with a Ubuntu live CD
After the desktop loads you will see your drives there. Open each one and check which is your C drive, and then go to Documents and Settings, and in your profile, Desktop
Select the file, press shift and press delete the file
Method 2 (may work)
Boot Windows in safe mode by pressing F8 on boot and making the relevant selection
Select, press Shift and press delete to get rid of it from Desktop
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
15-11-2008, 04:23 PM
#24 (permalink)
Davislav Ivanuiz!!!
Well, well, well!! 'Pearl Groupz' is back with another ID !!
Try unlocker and if that fails, boot using a live CD and delete the offensive piece of data. If that doesn't work either, check the disk for errors.
And next time, please try to use your head as well when you use the hand.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
15-11-2008, 04:52 PM
#25 (permalink)
AFK
Yeah...thats him. Mine mind new it was him
@OP
Use a live CD to delete the file. and use common sense next time.
Why are you running in 256 colours?
15-11-2008, 05:41 PM
#26 (permalink)
Wise Old Mouse
How you come to know about this?
15-11-2008, 05:46 PM
#27 (permalink)
The Black Waltz
#krow @ irc.freenode.net
15-11-2008, 05:49 PM
#28 (permalink)
Wise Old Mouse
But How????
#29 (permalink)
The Black Waltz
Use your head
Ok I'll PM you.
15-11-2008, 05:50 PM
#30 (permalink)
Rubik's Uncle!!
offtopic:
mine, mine, mine, mine, mine
remember the birds from "Finding Nemo" ?
Search this Thread |
