Old 14-11-2008, 06:08 PM   #1 (permalink)
RMN
Default Tata Indicom...how good is it?
im using a 512 unlimited plan from Asianet Dataline and get around 52-54 kbps D/L speed.
but my cousin gets 100kbps D/L speed on a Tata Indicom 256K connection!!
so im seriously considering about changing my provider and would like to get some feedback abt them.
tq
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 14-11-2008, 06:27 PM   #2 (permalink)
Default Re: Tata Indicom...how good is it?
52-54kbps on 512kbps and 100kbps on 256kbps. Both are bad.
I used to get 128kbps on TataIndicom plug to surf whiz modem !!
ThinkFree is offline
Old 14-11-2008, 06:43 PM   #3 (permalink)
was it kbps or kBps both are different things......if kbps its bad.........if kBps its probably good for 512kbps connection as 512kbps= 512/8=64kBps(10kBps less)
i hope this helps.
C2D E8400@3 Ghz, Radeon HD 4850, LG 224WS
adscience is offline
Old 14-11-2008, 06:58 PM   #4 (permalink)
M3TAL H3AD M3
skippednote's Avatar
How much does the tata indicom plug to surf cost.
I spit Rainbows.
skippednote is offline
Old 14-11-2008, 07:07 PM   #5 (permalink)
Rs. 2850 upfront
Tariffs here
But the service quality deteriorated a bit recently and that's why I switched from that.
Old 14-11-2008, 07:57 PM   #6 (permalink)
RMN
i meant Kilo Bytes Per Second
what D/L speed should a 256 and 512 broadband connection get?
RMN is offline
Old 14-11-2008, 08:11 PM   #7 (permalink)
256kbps=32kBps
512kbps=64kBps
Old 14-11-2008, 10:23 PM   #8 (permalink)
hahahari's Avatar
The 2Mbps connection I have have is good. I get a ful a 2mbps down and 512kbps up speed. I have 9 to 9 unlimited
www.harivarrier.com
Check out to earn money...
hahahari is offline
Old 15-11-2008, 11:22 AM   #9 (permalink)
RMN
Originally Posted by ThinkFree View Post
256kbps=32kBps
512kbps=64kBps
hmm...any idea how my cousin is getting 100kBps download speed from a 256kbps connection?
RMN is offline
Old 15-11-2008, 11:28 AM   #10 (permalink)
AFK
thewisecrab's Avatar
Are you sure that it is KBps? as that seems unlikely...
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 15-11-2008, 03:50 PM   #11 (permalink)
I don't think that it's possible to get 100kBps(=800kbps) on 256kbps unlimited use plan.
Old 15-11-2008, 07:48 PM   #12 (permalink)
still find time for games
arijit_2404's Avatar
He's dreaming. Show us some screen shot that he's getting 100 KBPS.
I'm using tata indicomm 384kbps unlimited plan. I'm getting 43-45 KB/s in utorrent constantly. Previously I was on 256kbps UL, I got 29-31 KBPS constantly.
In Firefox add-on Down'them all my download reaches 100 KBPS for 2 secs sometimes. If this is you're seeing then don't bother. Otherwise give us proof.
PhenomII X6 1055T | Gigabyte 890GX | 4GB GSkill Ripjaws DDR3 | XFX HD5770 | Samsung 943nwx | Coolermaster Hyper TX3 | Coolermaster Elite430 | Corsair HX750
arijit_2404 is offline
Old 15-11-2008, 11:04 PM   #13 (permalink)
RMN
im certain im not dreaming.
hmm...maybe he got it wrong with KB and kb....so looks like i don't have to change my provider.
btw the unit bit torrent shows is Kilo Bytes per Second right?
RMN is offline
Old 16-11-2008, 04:13 AM   #14 (permalink)
Can you hear it..??
windchimes's Avatar
I am using the same plan and it is good. I get about max of 206KB/s dl speed. What about you hahahari?
"Just Keep swimming"
windchimes is offline
Abt. TATA INDICOM MODEM chirayu garg Software Q&A 2 01-11-2008 11:52 AM
how good is tata indicom internet card(pcmcia port) tanmay_rajvanshi Internet & WWW 10 18-07-2006 12:36 PM
Tata Indicom (help) Chirag QnA (read only) 7 19-09-2005 12:17 PM
AMD & Tata Indicom Launches The PIC gxsaurav CPU / Motherboards 11 01-11-2004 11:13 PM
- by gforz
- by soumya
