Old 23-05-2005, 10:03 AM   #1 (permalink)
Default avg startup
hi i use avg free edition 7.0 antivirus system.i used registry cleaner to delete invalid entries,etc... in the registry..after that everything is fine..but my antivirus system is not activated automatically during startup.. how do i make this alright..?
thanks
karthik316_2003 is offline
Old 23-05-2005, 10:19 AM   #2 (permalink)
QA Juggler
saROMan's Avatar
well what u can do is start AVG and check if its configured to run at startup or not ...2nd go to msconfig ..and see if startup entry for AVG is disabled or not ......
IF u are undable to run AVG it means some registry entries are deleted ..so either reinstall or if there is option to repair the setup..repare the files ....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 23-05-2005, 12:51 PM   #3 (permalink)
im able to start avg normally..only problem is not able to bring it in the startup there is no entry for avg in the msconfig i don't know how to add it..and reinstalling is a big prob cuz its a 20 mb download constantly updated on the internet...
anyway thanks..
Old 23-05-2005, 12:56 PM   #4 (permalink)
QA Juggler
saROMan's Avatar
well what u can do is ..put a shortcut of avg in startup folder .....go to start->all programs->startup
right click on it and select open folder ...now just paste a shortcut of avg here .......hope it works for u...
saROMan is offline
Old 23-05-2005, 01:56 PM   #5 (permalink)
expertno.1's Avatar
if there is a fine startup then why do you want to add it in the msconfig ?
expertno.1 is offline
Old 23-05-2005, 11:33 PM   #6 (permalink)
u c there is something called avg resident shiled that USED TO LOAD automatically at startup..it detects the virus instantly for eg.,when a floppy containing virus is inserted into the drive..this is very useful is'nt it.?.its not possible for me to manually start the program eveytime i boot up..thats the reason i want to msconfig..
anyway will get back after trying the alternative of adding the shortcut to the startup folder
Old 24-05-2005, 12:04 AM   #7 (permalink)
swatkat's Avatar
What is the location (path) of the AVG installation? (For example, C:\Program Files\Grisoft\...)
http://swatrant.blogspot.com/
swatkat is offline
Old 24-05-2005, 08:01 AM   #8 (permalink)
expertno.1's Avatar
the path depends on the installation
at the time of installation you have to give the path
but we dont look anything and click on next
Old 24-05-2005, 10:03 PM   #9 (permalink)
the path is D:\Program Files\Grisoft\AVG Free
- by gforz
- by soumya
