You can get a trial of this app from the link at the bottom.
NetAdjust Anonymous Proxy is an Internet utility to let you browse the Web anonymously.
NetAdjust Anonymous Proxy lets you use another IP number which is provided by a server called anonymous proxy server as your unique identification number.
Also when posting to Web forums your message is stamped with your IP number.
NetAdjust Anonymous Proxy can be minimized to the system tray (next to the clock), where you can conveniently enable or disable it with a right-click.
Net adjust anonymous proxy
What are the features included in this anonymous surfing software?
- Hide your IP number from people.
- Check the availability of multiple anonymous proxy servers with a blazing fast speed.
- Import any list of anonymous proxy servers into NetAdjust Anonymous Proxy
- Export the list of anonymous proxy servers contained in NetAdjust Anonymous Proxy to .txt, .html or .xls.
- NetAdjust Anonymous Proxy automatically deletes dead anonymous proxy servers.
- Add or remove any anonymous proxy server to the list.
- Get Whois information about the proxies.
http://www.netadjust.com/anonymous-proxy.htm
