Old 11-11-2008, 06:26 PM   #1 (permalink)
hluachawngthu's Avatar
Exclamation Problem with Autorun.inf etc
1. Whenever I insert pendrive/camera in my USB port, my my Avast 4.8 Home Edition has detected 'autorun.inf' file. Is this can be overcome? and
2. Whenever I open my browser (IE6) to access the Net, my Avast 4.8 Home Edition has detected a virus "Win32elf-IFY [Trj]" in my Document and Settings folder.When I scan the folder, I did not found 'em. How can I delete or clean this virus from my system? Please advise.
hluachawngthu is offline
Old 11-11-2008, 09:38 PM   #2 (permalink)
swatkat's Avatar
Default Re: Problem with Autorun.inf etc
Your pen drive contains a virus. Update your AntiVirus and scan your pen drive once. Remove any malicious file your AntiVirus might find. Generally, viruses that spread through removable media use the Windows' auto-play (via Autorun.inf file) mechanism to launch themselves. And, Avast is blocking this execution, that's all.
Also, run a complete system scan using Avast.
http://swatrant.blogspot.com/
swatkat is offline
Old 11-11-2008, 09:47 PM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
Scan your PC/Pen Drive with a-Squared and SuperAntiSpyware
Literally Avast Sucks... go for AVG
Also don't forget to update their definitions before scan
Also you can refer to this Thread (The problem is solved here): http://translate.google.com/translat...3Doff%26sa%3DN
- MrinTech :)
mrintech is offline
Old 12-11-2008, 03:09 PM   #4 (permalink)
The Boy Who Lived
hjpotter92's Avatar
I will say the same. Avast is Bogus for me. and AVG is A-1
Core i7 920 @ 2.67 GHz
Intel DX58SO
3 GB DDR3 1600 MHz RAM
nVIDIA GeForce 9600 GS
Razer Arctosa + Abyssus
Please help: http://www.thinkdigit.com/forum/prog...p-windows.html
hjpotter92 is offline
Help!!! Problem with autorun.inf sarincv Software Q&A 5 23-06-2008 03:32 PM
Autorun.ini pritish_kul2 QnA (read only) 2 11-11-2007 06:10 PM
Problem with Autorun Disks CadCrazy Software Q&A 8 11-11-2006 08:02 AM
Autorun Gone... CD sourav QnA (read only) 5 02-05-2005 10:29 AM
autorun krishnansurya QnA (read only) 13 08-01-2005 01:50 PM
- by gforz
- by soumya
