Originally Posted by expertno.1
so goobimama have you tried reinstalling or updating IE ?
g00d point
While uninstalling, IE also provides a repair option - u can try that 2.
But 1st tell me, have you recently installed/uninstalled any software that supports unicode based writing in desi languages (hindi etc.)
Also c if these helps:
1. Control Panel>Internet Options (General Tab)> Accessibility> User Style sheet > uncheck "Format document using my style sheet".
2. Yor fontspecs cud hav been corrupted 2, try fontdoctor 2 fix if needed
If u just need 2 see a webpage rendered in IE engine, use Maxthon & change encoding from d view menu 2 "Western European".
Post feedback...
