Old 22-05-2005, 10:52 PM   #1 (permalink)
Default sudden restart
Help
I recently got windows XP installed on my computer. But now new problems have risen.
=> The computer restarts without any warning. I went into the power management options and disabled turning off hard disks and monitor after certain period. But this doesnt solve the problem.
=> I installed nero 5.5 on my computer. But when I tried to run nero , it gives an error that "the executable file of nero has been modified. Maybe the computer is infected with a virus. Do full system scan and try installing from an original nero CD." I am using the CD bundled with the combi drive. Before installing XP, I had the same problem in Me.
Please help me out of this problem.
visit:
http://skiewpoint.blogspot.com
http://aestheticblasphemy.blogspot.com
anshul is offline
Old 22-05-2005, 11:17 PM   #2 (permalink)
The Hardware Labs
mohit's Avatar
hi anshul... regarding ur first problem , it can be due to anything such as a faulty smps or loose wiring ... firstly make sure you have a GOOOD branded smps min 350 W for a normal system and 400 W if u have a high end gaming rig... go for brands like antec,powersafe etc. you havent mentioned your config , this problem can be due to overheating also ... make sure you have a very well ventilated cabinet with xtra cooling fans etc and make sure your cabinet is dust free ... if you are using an intel prescott then be prepared to face frequent overheating. also check for loose wiring and i suppose yo u have a good UPS also to protect against surges.
For the second problem i suggest you go to the dealer and get the nero cd exchanged for another as this cd seems corrupt to me.
mohit is offline
Old 23-05-2005, 12:21 AM   #3 (permalink)
sidewinder's Avatar
For a normaql system....300 watts is enough.But if u have multiple hdds,cd writers,powerfull graphics card then u need 350 watts nd upwards.
Regarding ur prob it could be anything
Check ur system for virus
Update ur drivers
Check wirings
Check ur psu
For a system such as p4 2.8 ,512 Ram,80 gb hdd,Fx 5200,DVD ROM,Cd writer... 300 watts is perfect provided its truly 300 watts.
Bombina rocks
sidewinder is offline
Old 23-05-2005, 01:14 AM   #4 (permalink)
hey i THIS IS WAT MY CONFIG WILL BE LIKE SUGGEST ME A GOOD SMPS AND UPS (CHEAP !!!)
LET ME TELL U VIP/ANTEC/POWERSAFE IS NOT AVAILABLE IN JABALPUR!!!
AMD ATHLON 64 2800+/3000+/3200+
ASUS K8N-E DELUXE
TRANSCEND DDR 400 512MB
GeForce Fx 5700Le
SAMSUNG / SEAGATE (PUMA/BARACUDA)(SATA)80 GB
COMBO or MAYBE (CD writer & DVD ROM DRIVE !!!)
SMPS - company????? WATTS ??????
UPS - COMPANY ???? 500va or 600 va?????
HEY HELP ME !!!
CHEERS !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 23-05-2005, 04:22 AM   #5 (permalink)
expertno.1's Avatar
mr King_Niral your congiguration looks pretty good
expertno.1 is offline
Old 23-05-2005, 06:39 AM   #6 (permalink)
sidewinder's Avatar
Buy I box cabinet.The smps that comes with it is very godd.Or u can buy VIP.Whatever u buy make sure that it supplys 14amp at least in +12 volt rails.U can get this info from the sticker on the psu.If u r buying a new rig then look for 350 watts.U can buy 400 watts but that will cost u a bomb
Bombina rocks
Old 23-05-2005, 08:02 AM   #7 (permalink)
expertno.1's Avatar
thats a good suggestion sidewinder
Old 23-05-2005, 08:09 AM   #8 (permalink)
expertno.1's Avatar
ok i will try a it my self
Old 23-05-2005, 09:15 AM   #9 (permalink)
i box is good. I would also suggest frontech. i am not sure if its available in your area. i have been using it for the past 2 years and it has been good.
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
Old 23-05-2005, 10:17 AM   #10 (permalink)
Frontech is available here !!! hey Watz the cost of i box approx ???
plz guys ne1 has a config like mine ??? coz i still have 2 pick up my processor and i had gone 2 this computer guy and he told me i made a mistake selecting AMD !!! he says it still has the overheating burning out problem !!!!
I am a bit worried so i have thought to blow it wit fans from every angle !!! Even DRILL into the case to fit faNs !!!
Thanx expertno.1 !!!
PLz help me !!!!
I am getting an intex ups for Rs1650 and Numerice for Rs2200 I knw Numeric is GOOD but is INTEX sufficiet for my NEEDS ????
Cheers !!!!
Old 23-05-2005, 12:44 PM   #11 (permalink)
The Hardware Labs
mohit's Avatar
@ king_niral
hey buddy here are my suggestions
dont go for a socket 754 amd , go for socket 939 if it is in your budget.
if u can't go for socket 939 then for socket 754 go for this board ASUS K8N4-E-DELUXE (nforce 4 chipset)
Ibox smps is no good and neither are any brands like frontech,intex etc ... i am having an ibox cabinet but then i changed the smps to an antec as i was facing problems like restarts. Better get an antec or powersafe smps somehow through your local dealers or you can do what i did ... contact antec (contact available on the contacts sticky) and ask them if they are ready to ship u a smps provided you pay shipping and all taxes etc.
UPS - strictly avoid Intex and go for a 600 VA Numeric instead. it is better than intex anyday. you can also try APC/TVS
HDD dont go for Samsung. Go for Seagate SATA/SATA 2.
Also try buying 2 * 256mb ram modules instead of 1 512mb ... as you will able to use dual channel and also be safe if one gets screwed.
Lastly avoid the 5700 Le card ... LE cards are no good. go for a vanilla 6600 if in ur budget instead of the 5700 le.
mohit is offline
Old 23-05-2005, 11:42 PM   #12 (permalink)
Originally Posted by mohit
@ king_niral
Hey thanx for the suggestions man it will help me !!!
a slight update i forgot to add it above !!!
AMD ATHLON 64 2800+/3000+/3200+ (NOT BOUGHT!!)
ASUS K8N-E DELUXE (BOUGHT FROM LAMINGTON ROAD MUMBAI !!! )
TRANSCEND DDR 400 512MB (BOUGHT FROM LAMINGTON ROAD MUMBAI!!!)
GeForce Fx 5700Le(BOUGHT FROM LAMINGTON ROAD MUMBAI !!!)
SAMSUNG / SEAGATE (PUMA/BARACUDA)(SATA)80 GB (NOT BOUGHT!!!)
COMBO or MAYBE (CD writer & DVD ROM DRIVE !!!) (NOT BOUGHT!!)
SMPS - company????? WATTS ?????? (NOT BOUGHT!!)
UPS - COMPANY ???? 500va or 600 va????? (NOT BOUGHT!!!)
The ASUS K8N-E DELUXE does not support DUAL DDR MODE!!!
IT has only 3 RAM SLOTS !!! And anyway within 3 odd months i would Upgarde RAM to 1gb(Transcend DDR 400 512Mb x 2) !!!
I have tried to ake the system powerful according to my budget and very much future proof !!!
i will upgrade to Best card around in a year'z time.
2Gb o RAM !! the 3700+ processor !!!
then with this kinda config the Baby Will Rock !!!
Cheers !!
Old 24-05-2005, 06:40 AM   #13 (permalink)
sidewinder's Avatar
PLz help me !!!!
Dude puttung in more nd more fan is not the one.In fact if wrongly done it can get more worse.Arrange three fans this way.At the lower part or in the front a fan intaking air.....cpu fan (leave it as is)...then a fan just besibe cpu fam with air outward direction.
And AMD is best but everybody donno hot to assemble it.I have an amd athlon xp 2200+,AMD 64 3000+ and Athlon xp 1800+.The highest temp i ve ever noticed is 49c that too with 1800+.And I dont use any special cooling solution.
Cheers !!!!
Bombina rocks
Old 24-05-2005, 06:45 AM   #14 (permalink)
sidewinder's Avatar
Dude puttung in more nd more fan is not the way.In fact if wrongly done it can get more worse.Arrange three fans this way.At the lower part or in the front a fan intaking air.....cpu fan (leave it as is)...then a fan just besibe cpu fam with air outward direction.
Bombina rocks
Old 24-05-2005, 07:35 AM   #15 (permalink)
expertno.1's Avatar
hey why not to go for 500 GB hard disk !
Old 24-05-2005, 10:18 AM   #16 (permalink)
i will have to disagree !!! There is only 1 company who is making 500Gb and that is Hitachi !!! the cost of a P-ATA drive is $500 & S-ATA II which is S-ATA I compatible !!!
The cost of 6 S-ATA 80Gb drives works out to 18,000 !!! THATS A DIFFERENCE OF 5k+ SO I doubt any one will go in for a 500gb so soon !!!
If they require that muc of space they WILL DEFINETELY FOR 6 HDD's IN RAID !!! AND i think all of u will agree with me !!!!
Cheer !!!
Old 24-05-2005, 11:53 AM   #17 (permalink)
anomit's Avatar
There can be two causes behind your problem:
1. It is the problem of heating up as all others have mentioned.
2. This is a bit unique. You should check your computer if there is any file called reboot.exe. This is a virus.
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 24-05-2005, 05:08 PM   #18 (permalink)
Hey try wat anomit says ??
cheers !!!!
Old 24-05-2005, 07:09 PM   #19 (permalink)
49c?????mine max gone to 70 c................amd xp 2600+......i also avoid overclk becoz of this temp...it remains mainly stable b/w 63 too 67........
magnet is offline
Old 24-05-2005, 10:55 PM   #20 (permalink)
sidewinder's Avatar
yes buddy...49c that too with oem hs/fan.Ur temp is very high...
Bombina rocks
Old 25-05-2005, 06:18 AM   #21 (permalink)
sidewinder's Avatar
Out of my three computer two have ibox cabinet nd i never faced any problem with them.U have a problem doesnt mean that they r bad.In fact its much better than techcom or frontechs.
Lastly why always compare it with antec.....IBOX full tower cabs with 350 watts psu will cost u 1200-1400 nd only psu of antec will cost u 2000.
Antec is certainly better than ibox but only if u can afford it
Bombina rocks
Old 25-05-2005, 10:49 AM   #22 (permalink)
Hey i think ur boasting about buying an ANTEC cabinet !!! But according to me ur using 1 monitor COZ U NEVER NOTICE THE TEMPERATURES MORE THEN 49c in ur systems !!!! how can when one sysytem is working the other 2 r off !!!!
@sidewinder DON'T BOAST !!! COZ U DON'T KNOW WHOZ AROUND U !!!
WHO COULD ME WORSE THEN U !!!!
AND My system i was ASSEMBLING !!! I HAVE ASSEMBLED MORE SYSTEMS THEN THE NUMBER OF YEARS U HAVE BEEN LIVING x 10 !!!
SO BE GOOD TO ALL !!!!
AND SPECIALLY MY PAL expertno.1 !!!
CHEERS !!!
- by gforz
- by soumya
