Old 22-05-2005, 09:04 PM   #1 (permalink)
Default AresLite Problem
I had recently installed AresLite for P2P sharing as it is
very light on computer resources.
The problem is that when I connect the internet and
open AresLite, it keeps the bar on Connecting mode only
and doesn't change to Online Mode.
it takes quite a hell out of time before it changes its mode to online.
what could be the problem???????
i have disabled all the firewalls.
i am using Win XP Pro
It\'s a truism that our worst affected wounds are self inflicted
Just Another F*$%/ed up day in Paradise
SHell is offline
Old 22-05-2005, 10:16 PM   #2 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
I am using Ares, it gets connected generally.
This may occure if u change the setting
Have You Changed the Settings??....
Check this....
Click on the Control Panel, then on to Transfer tab;
Make sure .... Allowed Upload bandwith to atlest 8 or 0
This should solve your problem
rollcage is offline
Old 22-05-2005, 10:27 PM   #3 (permalink)
Have u installed n e other firewall protection software?
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 22-05-2005, 10:44 PM   #4 (permalink)
No I have not change the settings.
and I have no other firewall installed on my computer.
yet the problem persists....plz help
SHell is offline
Old 22-05-2005, 11:22 PM   #5 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Even before u read your post , i guessed wht's the problem is. Most of us have this problem.
I just uninstalled it and installed it and it connected for me. Also have ur firewall disabled.
It's a common problem, don't worry...
drgrudge is offline
Old 23-05-2005, 12:13 AM   #6 (permalink)
for me some times it connects instantly sometimes it takes a while to connect...so i guess nothing to worry
atool is offline
Old 23-05-2005, 04:57 AM   #7 (permalink)
expertno.1's Avatar
try reinstalling and changing the settings properly
expertno.1 is offline
Old 25-05-2005, 01:09 AM   #8 (permalink)
Uninstall Ares, Create a new adminstrator account in XP and install ares in that new account. I hope this will definitely help you.
- by gforz
- by soumya
