Old 10-11-2008, 10:28 AM   #1 (permalink)
vikasg03's Avatar
Default How to change file system
Hi,
I did one mistake, is there any chance to fix this. I have window xp proff (winthout service pack) installed previously in my system. Yesterday, what i did is, i run the window xp proff cd including SP2, , it gives the upgrade option, and i click that. By mistake during installation i selected the ntfs file system, But previously my file system was FAT32. now after installtion, i am not able to open any file. system is very-2 slow. It shows all my previously installed softwares and programs Is there any way to rollback?. I forgot to create restore point and my system restore was off.
Any chance or way to back to fat32 position.
vikasg
Vikas
vikasg03 is offline
Old 10-11-2008, 11:55 AM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Lightbulb Re: How to change file system
(Just copy all files from it e.g. to other drive, if you do so.) (you have to format the disk)
In WinXP, you can execute following command for your disk you want to format (replace the "z:" to your drive):
"format z: /FS:FAT32"
(from command prompt)
I think you have to format the partition as you are going back from NTFS to FAT 32
- MrinTech :)
mrintech is offline
Old 10-11-2008, 12:04 PM   #3 (permalink)
vikasg03's Avatar
Default Re: How to change file system
Oh.. Is it not possible if i re run the setup and then this time i select fat32 as a partition, so it gives me my old OS back. I wonder, why and how it is converted to ntfs without loosing data during upgrade because it shows all of my programs and files. that's why i want to know without formatting no change to back to previous position.
Vikas
vikasg03 is offline
Old 10-11-2008, 01:03 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
I am not sure whether NTFS to FAT 32 is possible without data loss. Partition Magic can do this, but you have to buy it.
Wait what other Digitians say.
Rest atleast move your important file and data to other drive/removable media if a need of format arrives.
- MrinTech :)
mrintech is offline
Old 10-11-2008, 02:17 PM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: How to change file system
[Offtopic]Got it!!!
The thrd was not showing in New Posts and I forgot where it was posted[/offtopic]
I've some links for u.
Check those.
http://forum.notebookreview.com/showthread.php?t=129952
http://ubuntuforums.org/showthread.php?t=272792
http://www.techsupportforum.com/micr...tfs-fat32.html
http://forums.pcworld.co.nz/showthread.php?t=35970
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 10-11-2008, 02:24 PM   #6 (permalink)
Wise Old Mouse
mrintech's Avatar
Originally Posted by rhitwick View Post
[Offtopic]Got it!!!
Check those.
dude he is asking for NTFS to FAT 32... not FAT 32 to NTFS....
Still i think the drive must be formatted or get your hands on partition magic
- MrinTech :)
mrintech is offline
Old 10-11-2008, 02:27 PM   #7 (permalink)
Democracy is a myth
rhitwick's Avatar
Dude, have u checked all those FOUR links??? I guess not, then u would not have posted this.
Old 10-11-2008, 03:03 PM   #8 (permalink)
Wise Old Mouse
mrintech's Avatar
OKz
- MrinTech :)
mrintech is offline
How to change the extention of any file? hpotter606 QnA (read only) 4 10-11-2008 11:42 AM
file change monitor software tweety_bird_bunny Software Q&A 4 05-02-2008 12:54 PM
Change File size! romeo_8693 QnA (read only) 11 04-11-2006 12:29 PM
Change File size in MB instead of GB in properties of a File rachitar QnA (read only) 4 24-11-2005 09:46 AM
How to change an icon of an .exe file??? go4saket QnA (read only) 4 09-10-2005 08:02 PM
- by gforz
- by soumya
