View Poll Results: what is better:
running cpu for continiously for 8 hrs 2 50.00%
running cpu for 2 frs 4 times in a day 2 50.00%
Voters: 4. You may not vote on this poll
Old 03-09-2004, 11:32 PM   #1 (permalink)
dhawald's Avatar
Default HOT! computer problems help
i have p4 1.8 ghz,512 mb ram,
64 mb ati graphics card and intel D845GEBV2 board
i have installed intel active moniter
which keeps an eye on the cpu temp
when i play games such as
halo or rise of nations the program
gives an alarm after 15-20 min that
the temp of
processor zone is > 60 'C
system zone1 is > 50 'C
system zone2 is > 55 'C
the fan is running properly
is this normal???
up to what tempretures cpu is safe
from where can i get a good info on that
dhawald is offline
Old 03-09-2004, 11:48 PM   #2 (permalink)
look like u live in some hot place coz i didn`t find any cooling prob with me, my system is on from last 4 days and no prob.
go for some extra fan, or go for water cooling solution
even in hevy stuff games i didn`t find this prob so just check out
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 04-09-2004, 01:03 AM   #3 (permalink)
gxsaurav
Posts: n/a
U R now talking to the biggest cooling freak on Digit
CPU FAN, Zalman CNPS AlCu 7000
1 rear Exhaust, 1 front intake & I side exhaust,
Now for U, the CPU temp is normal, P4 can go for a max of 71C before it starts to decrese it's speed wit h10% limits, if it's too hot your cpu will decrese 180 MHz, if still hot, more 180 MHz till the temp comes to normal, don't worry
However your motherboard & aux temp are really high, they should never go over 42C, U better Open the cabinet side panel when Using your PC
& use your PC as long as U want, I have to close my PC cos I have to go away from my PC,
Old 04-09-2004, 11:40 AM   #4 (permalink)
For a willamete thats too high a temperature i guess. I have stock cooling, 2 fans and the idle temps are 38c while on full load they go arnd 50c max. Try thermal paste, get a good brand like artic silver. Also chk if the fans are working properly and blowing out air. If this doesnt work u can add extra fans to ur cabinet. Also try this, keep the cabinet open and then play the games etc and then chk the system temps. Report back here.
EDIT: Have u overclocked ?
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 04-09-2004, 12:33 PM   #5 (permalink)
gxsaurav
Posts: n/a
blade I don't know where U R but is Artic silver 5 or ceramique available there, if yes then plz tell me the cost & how can I get it here in lkw
Old 04-09-2004, 02:51 PM   #6 (permalink)
I am frm mumbai.......The AS5 and Ceramique paste is available at Prime ABGB at lamington road.
E-mail: primeservices@vsnl.com
Contact: 022-23896600. The AS5 costs arnd 650/- but i heard due to massive demand there was a price hike and it went upto 800/-. U can contact prime ppl and they might ship it to lucknow if possible.
Edit: Ceramique for 550/- but get it confirmed by mailing them.
Old 04-09-2004, 03:07 PM   #7 (permalink)
i got it confirmed.AS5 is 650 and ceramique is 550.
nikhilesh is offline
Old 04-09-2004, 05:06 PM   #8 (permalink)
why is this guy posting all over the place ?
anyways .. see what blade wrote ..and check ur other thread as well
sheesh
No Mercy, No Limits.
theraven is offline
Old 04-09-2004, 05:40 PM   #9 (permalink)
gxsaurav
Posts: n/a
Well there is no way, I can come to Mumbai, I have mailed them, although I m using the thermal compound which came with my Zalman, but still if U can buy & ship me the AS5 tehn it will be good, I will pay U, tell me how can I pay U
Old 04-09-2004, 05:45 PM   #10 (permalink)
Hmm.....wait for their reply first. They usually ship it to places .....If thats not possible then we'll see what can be done .......
- by gforz
- by soumya
