Old 08-11-2008, 12:25 PM   #1 (permalink)
Question How to make one dvd from multiple cds?
Hi there
calling all u writing gurus out there.i would like to know how to combine an install spread over a number cds into one dvd?for example the VS.net 2003 comes as a 3 cd install pack.will it work if i copy all of the files into one file and write it into a dvd?same goes for games too.anybody any ideas?
helboy is offline
Old 08-11-2008, 09:17 PM   #2 (permalink)
swatkat's Avatar
Default Re: How to make one dvd from multiple cds?
Here's one solution:
http://www.magiciso.com/FAQ/FAQ0001.htm
That may or may not work, as the installation depends on the installer stub. If the installer looks for subsequent CDs (even though data is there on the same DVD), then installation may fail.
http://swatrant.blogspot.com/
swatkat is offline
Old 09-11-2008, 06:03 AM   #3 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Originally Posted by helboy View Post
Hi there
Here is what I do:
If you own the original CDs, You can make backup images ( ISO images using Nero or any other software) and burn those images on DVD. Whenever you want to use them just mount them using Daemon Tools or Nero Image Drive.
Quiz_Master is offline
Old 09-11-2008, 08:55 AM   #4 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
Try the "ULEAD MOVIE FACTORY 5" ITS FREE U CAN DOWNLOAD
GAMING RIG=>C2DE8500 | ASUS P5Q PRO |3GB DDR 800 |VIEWSONIC VX1932WM|CM 600 WATTS |PALIT 4850
PC RIG=>AMD PHENOM X4 9550 | ASUS MOBO |2GB DDR 667 |CORSAIR 450 WATTS |17"TFT LG |2 TB SEAGATE
ultimategpu is offline
How to make multiple choice Questions? jack_the_ripper QnA (read only) 3 04-06-2008 09:51 PM
Make Multiple Boot DVD krishnandu.sarkar Software Q&A 1 22-12-2007 10:41 AM
how make make anyone(unregistered users) post on my blog? kerthivasan QnA (read only) 5 23-07-2007 09:18 PM
How To Add Multiple MX Entries And Set Multiple Preference? tuXian QnA (read only) 7 03-03-2005 06:23 PM
- by gforz
- by soumya
