Anybody using an Nvidia FX card should definately try these drivers from Guru3D, although they are not official but they are WHQL that means they came from nvidia & MS originally, so no worries
The Image Quality & performance in Doom3 is up by a lot & even in far cry, I don't have DirectX 9c, (SP2 RC2 has beta DX9c) so I can't run that anidex's Shader program but I will release my results for that as soon as I get DX9c or SP2.
I got my Chip from my friend, my 3DMark03 score
61.77 official, 4125
65.53 4344
Also NFS underground doesn't hangs anymore, playing at my settings
Make sure to delete all the other language files after installation, to free up about 14 MB space as it comes with multilanguage files, like russion, deleting them manually after installation will cause no problem
