Old 22-05-2005, 07:59 AM   #1 (permalink)
Default compaq deskpro ep/sb series not detecting hard disk disk
hi my compaq deskpro ep/sb series is not detecting hard disk samsung 8.2 gb
all the wires are correct what to do?
aditya169 is offline
Old 22-05-2005, 11:47 AM   #2 (permalink)
hey check ur jumper setting !!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 22-05-2005, 12:59 PM   #3 (permalink)
Follow Kings advice and check your jumpers. Use Cable Select (CS) instead of Master or Slave if you have any problems in these modes.
CS is preferred if you have WD hard disks.
Keith
Keith Sebastian is offline
Old 22-05-2005, 07:14 PM   #4 (permalink)
Default still didnt work
I checked the jumper , i kept it in all pins one by one still it didn't work
is their a need to update bios ?
what do u mean by this ?the normal cable is pluged in to the hdd and motherboard
- by gforz
- by soumya
