Old 05-11-2008, 10:22 AM   #1 (permalink)
Default Suggestions Needed For RAM Upgrade.
I want to upgrade the RAM of my Hp Pavillion PC having following configuration Pentium4 541 (P) HT 3.2 GHz:Intel 915G
Memory Installed:512 MB (2 x 256)
Memory Slots Available:4
Now i want to upgrade my RAM by adding 3-4 I GB RAM sticks.I just want to know whether my PC will practically support 4GB of RAM or will it be advisable to keep my RAM just little above 3GB,say 3x 1GB + 1x 256MB.
Please suggest...
muzaib is offline
Old 05-11-2008, 10:32 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Suggestions Needed For RAM Upgrade.
if ur mobo has 4 RAM slots then u can upgrade upto 4GB of RAM
use everest or other benchmark tool 2 get the exact RAM frequency needed/supported
Zangetsu is offline
Old 05-11-2008, 12:00 PM   #3 (permalink)
Violent serenity.
Psychosocial's Avatar
Yes, your PC will support 4GB RAM. But it only supports DDR2 533MHz RAM and DDR444 RAM. So I suggest get 1x4GB DDR2 533MHz RAM and unplug and throw away the old ones.
Psychosocial is offline
Old 05-11-2008, 12:24 PM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
to the OP:
well no need to throw away ur old RAMs, since u already hv 2x256 MB RAMs wich is occupying 2 slots, so the remaining 2 slots can be installed with 2x1GB so making a total of 2.5GB of RAM..
else, u can beat this config and get all 4x1GB rams and make a total of 4 GB RAM in DUAL channel mode..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 10-11-2008, 02:37 AM   #5 (permalink)
Thanks for your suggestions...
muzaib is offline
Old 10-11-2008, 12:16 PM   #6 (permalink)
yup, not a problem buddy..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Upgrade suggestions sahilshah1987 Hardware Q&A 12 30-09-2008 01:40 PM
Suggestions for Upgrade Ultra_Bloodshed Hardware Q&A 13 01-08-2008 07:43 PM
Upgrade Suggestions? devilz666 QnA (read only) 2 26-10-2007 03:49 PM
Suggestions for my upgrade Aparajith Hardware Q&A 2 28-04-2006 04:34 PM
suggestions :help to upgrade my pc!!! go_gamez Hardware Q&A 7 10-04-2006 02:07 PM
- by gforz
- by soumya
