Old 04-11-2008, 12:49 PM   #1 (permalink)
Default Any grphics card for system with 180 watt power supply..plz help
Hi,
I have recently purchased a Compaq 3540 model. Had to buy this coz i was not comfortable with assembled PC...
now i have a situation in hand...my system has only 180 watt power...now as per my knowledge no recent graphics card will run in this less power...is there any other dedicated graphics card that i can use which will have at least 256 mb dedicated onboard memory..plzz help..
incase its not possible, how much i have to spend to upgrade to a 400 watt SMPS?
plz help me guys as i have recently acquired some latest games and want to try those out.
thanks
Sunny
sunnythedreamer is offline
Old 04-11-2008, 01:50 PM   #2 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Default Re: Any grphics card for system with 180 watt power supply..plz help
Whats your screen size/resolution at which you will be playing? If you wanna play latest games at good resolutions with effects turned on, you'll need to upgradé the PSU as a GFX card for such a purpose will not run comfortably on a mere 180 watt power supply. Cards like ATi HD4850 itself need more than that. And changing the innards of the system may void the warranty, dunno...
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 04-11-2008, 03:26 PM   #3 (permalink)
I have the HP w1907 LCD monitor (19")..it has a resolution os 1440 * 600 or something..not sure..
I feel cheated by Compaq...never knew they are such craps who sell 180watt at this age...:/
Old 04-11-2008, 03:39 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Originally Posted by sunnythedreamer View Post
Hi,
thanks
Sunny
And I thought only I had soo less, I have 250W PSU
Well, the new Chrome ULP cards will work, which have a TDP of 7W but gaming, forgt it.
Buy this:
CM460W @ 2.2k
Now u'll be able to plug in a 9800GT, 9600GT, HD3850, HD3870 and all.
About me:
http://about.me/preetam_nath
comp@ddict is offline
8800 Ultra + 1000 Watt Power Supply GauravCJ QnA (read only) 9 12-02-2009 03:06 PM
grphics Card in HP pavillion Dv6502au latino_ansari QnA (read only) 3 14-08-2007 06:29 PM
determine power supply watt freakabhishek Hardware Q&A 16 30-08-2006 07:49 AM
- by gforz
- by soumya
