Old 03-11-2008, 09:08 PM   #1 (permalink)
The Boy Who Lived
hjpotter92's Avatar
Question Enabling Autoruns
Well, my autorun has been disabled, and I couldn't find a solution to it in the MS Troubleshoot... So just put it here.
Core i7 920 @ 2.67 GHz
Intel DX58SO
3 GB DDR3 1600 MHz RAM
nVIDIA GeForce 9600 GS
Razer Arctosa + Abyssus
Please help: http://www.thinkdigit.com/forum/prog...p-windows.html
hjpotter92 is offline
Old 03-11-2008, 09:54 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Wink Re: Enabling Autoruns
Here is how u do it.
Go to "Run"-->type "Gpedit.msc"-->Computer Configuration-->Administrative Template-->System
Click on System on left side and on the right look for "Turn On Autorun/Turn Off Autorn" (according to ur current state).
Double click it.
After that I guess u can do it.
Now the fun is that if u go to User Configuration-->Administrative Template-->System and do exactly above, u'll find another "Turn On Autorun" again.
AND I FORGOT WHICH ONE TO USE. I guess it should be User Configuration as windows remembers settings according to user privileges.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 04-11-2008, 09:05 AM   #3 (permalink)
slugger's Avatar
Default Re: Enabling Autoruns
Enable or Disable Autorun
slugger is offline
Old 04-11-2008, 03:17 PM   #4 (permalink)
The Boy Who Lived
hjpotter92's Avatar
Thanks that solved the problem.
Intel DX58SO
Enabling TTF support in GD DizitalNovice QnA (read only) 1 12-10-2008 10:31 PM
AutoRuns Utility for Windows. anandk Software Q&A 1 28-06-2007 09:37 PM
Enabling 'SUDO' anantkhaitan Open Source 2 17-04-2007 04:42 PM
Enabling DMA in Nero 6 sushantasarkar Software Q&A 1 31-10-2006 11:51 AM
Help enabling GD2 Support in php??? REY619 QnA (read only) 2 25-09-2006 11:35 AM
- by gforz
- by soumya
