Old 03-11-2008, 07:32 PM   #1 (permalink)
Can you hear it..??
windchimes's Avatar
Question How to make subtitle in synch with the movie?
Guys,I've few movie files with subtitles (.srt format ) which are not in synch with
the movie. Is there any way to correct the file either editing that file or using any
options in mediaplayer (does Klite have any option..??)
"Just Keep swimming"
windchimes is offline
Old 05-11-2008, 12:08 PM   #2 (permalink)
Norms Buster
Default Re: How to make subtitle in synch with the movie?
There is a sync option in the latest VLC.
VexByte is offline
Old 05-11-2008, 12:13 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Also, if there is no sync option, this type of error or mismatch arises wen u DONT hv the correct type of subtitle file (.srt file) for ur version of movie, say sum movies are Xvid rips, sum are DivX rips adn sum are jus avi..and wen u DO NOT use the correct type of .srt with the compatible movie, this occurs..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 05-11-2008, 12:26 PM   #4 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
The best software out there to play with subtitles files is Subtitle Workshop..
You can download it from here http://www.urusoft.net/download.php?lang=1&id=sw
The synchronization problem is due to the fact that the movie file is encoded in different FPS than the subtiles file..
You can set the FPS of the subtitles file and preview it simultaneously in the software.
Just choose the option of 'Load movie automatically..."
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Old 05-11-2008, 12:30 PM   #5 (permalink)
yup, tats wat i also said abt the fps thing (but in a more elaborated way)..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 05-11-2008, 12:56 PM   #6 (permalink)
AFK
thewisecrab's Avatar
In Kantaris. you can set a delay (in no. of seconds) after which you want the subtitle to be shown.
Like if it's too far ahead, insert a delay of 4 secs.
But this only works in Kantaris and does not fix the issue...
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 06-11-2008, 09:55 PM   #7 (permalink)
Can you hear it..??
windchimes's Avatar
Thanks guys.I wasnt looking fora 3rd party tool. And yes I knew regarding
that fps thing..And yes in VLC there is an option.
In Klite too there is a delay option, But can't
give -ve values in delay.. else it could've
fixed the issue.
Software for synch my phone contacts and archiving sms sganesh Open Source 2 16-09-2008 12:54 AM
how to make subtitle file assddd QnA (read only) 8 29-07-2007 04:18 AM
How to make DVD containing 6 movie gau_pppu Tutorials 11 19-06-2007 08:19 PM
Can i make a movie ? shreyadr QnA (read only) 10 10-06-2006 10:24 AM
- by gforz
- by soumya
