Old 21-05-2005, 08:33 PM   #1 (permalink)
Default MY MULE UPLOADS TOOOO MUCH!!
I had installed emule a week back after reading so many positive reviews from you guys about it....but the probem is its uploading a HELL LOT than its downloading......just to give an idea upload speeds are 25-30KB/sec on average and download speeds are a mere 10-15KB/sec....i cant cancel the uploads too as its not supported....it keeps uploading the same file which iam downloading SIMUNTANEOUSLY..... please help me....i am really going crazy!!!!
sahil_blues is offline
Old 21-05-2005, 09:00 PM   #2 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
go to options
connections
see the upload speed
degrade it to say 4
but mind you that will also affect your download speeds
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 21-05-2005, 09:02 PM   #3 (permalink)
i can get a max download speed of 60 KBps.....by how much will the download speed be affected if i reduce the upload speed to 4KBps???
Old 21-05-2005, 09:06 PM   #4 (permalink)
i dont know by how much exactly it will degrade your download speeds
but i say you rather try it
and see by how much the dlownload speed goes down
you can always go back to the speed setting you had earlier
just note them down before trying to modify them
Old 21-05-2005, 10:57 PM   #5 (permalink)
it doesn't effect the download speed by decreasing the upload speed. If you upload more to some1 you get credit in emule.
Credits reward users who upload. The transferred amount of data determines the amount of credits. Credits are not global, i.e. the can only be used on the client who grants the credits.
Credits are a major modifier when calculating the progress in another client's queue. The more credits you have the faster you will advance.
\"Let this world be a little better because I came here.
stalin is offline
Old 22-05-2005, 06:01 AM   #6 (permalink)
expertno.1's Avatar
it affects the speed if u cahnge the limit speed of download
expertno.1 is offline
Old 22-05-2005, 02:05 PM   #7 (permalink)
Just Do It
Charley's Avatar
Exact. Download speeds depend on the users ur downloading from. Even if u have a very fast connection say for eg 1mbps, the speed will not vary cos the person ur downloading is the factor which means ur download speed cannot be greater than his ..........
Charley is offline
Old 22-05-2005, 03:00 PM   #8 (permalink)
the best is Kazaa lite ressurection !!! its freeware !!! check it out !!!! been using the Kazaa network for over a year now!!!
Cheers !!!!!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 22-05-2005, 06:27 PM   #9 (permalink)
Use Netlimiter
I have been using it for ages.
It will solve your problem.
regards
mR_iNDIA is offline
Old 22-05-2005, 06:40 PM   #10 (permalink)
Originally Posted by mR_iNDIA
Use Netlimiter
regards
can you explian what exactly it does???
Old 22-05-2005, 07:39 PM   #11 (permalink)
Just Do It
Charley's Avatar
Use Netlimiter
regards
Dude , do a google search and will find all the details on it.
Charley is offline
- by gforz
- by soumya
