Old 01-11-2008, 10:48 PM   #1 (permalink)
__Virus__'s Avatar
Default Subtitles
I am almost afraid to ask this question. There are so many guides available, but I wish to begin from scratch. Searching on this forum returned quiet satisfactory results but din't help much.
I've many VOB files (series of movies precisely) and would like to reburn them, but this time getting proper sub titles in place. How can I achieve this?
Once I am well practiced with answer to the first question, second, where do I get subtitles for VOB files (movies precisely)?
Do we have any specific rules such as, the VOB files must all be grouped together in one file before using the subtitles or chunk of files can still work, etc.
Thank you very much for any help.
Some million years ago, the gods put down there feet, So firmly in to the ground that no man of sword nor pen, could ever chains the rules upon which The very fundament of metal was made.
__Virus__ is offline
Old 02-11-2008, 02:35 AM   #2 (permalink)
asia://india/ka/bangalore
a_to_z123's Avatar
Default Re: Subtitles
VOB files are container files, i.e. they contain subtitles within them.
So if your files already have badly synchronized subtiles then you can do nothing about them.
(I think Nero Recode provides the option for removing subtitles, but I haven't tried it)
Secondly, you can get subtitles from these two sites. You'll find subtitles for most of the films
www.subscene.com
www.opensubtitles.org
That should help you I think!
:) I've got my F, C and K . Now all I need is You !!! :)
a_to_z123 is offline
Old 02-11-2008, 03:40 AM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
And here too:
http://www.subdownloader.net/
This is one useful software, you should definitely try it!
dheeraj_kumar is offline
Old 02-11-2008, 10:48 AM   #4 (permalink)
Cool Buddy's Avatar
you can try subtitle worksop for editing the subtitles after you download or extract them, I didn't find it much useful though, but seems I didn't use it much either, so I'm still suggesting it.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 02-11-2008, 04:07 PM   #5 (permalink)
Originally Posted by dheeraj_kumar View Post
And here too:
The info on the website is very sketchy. What exactly does it do?? Does it actually search the net for subtitles of a specified movie?
Raccoon is offline
Old 02-11-2008, 05:45 PM   #6 (permalink)
Yes. It creates a hash for your video file, and searches its online database for any subtitle matching that hash. If so, it downloads it for you. If you have a video file, and a matching subtitle file, you can upload the subtitle automatically with the video's hash, so others can use it too.
Old 02-11-2008, 08:54 PM   #7 (permalink)
Thats cool! I just hope they have a really good database... most of the movies I see are quite obscure... Will try it soon.
Raccoon is offline
Old 02-11-2008, 11:24 PM   #8 (permalink)
__Virus__'s Avatar
Thank you all for the reply.
I am wondering why, even though I have many VOB files the subtitles never show up. There are some which show and there are some which don't. Am I missing something? And once I have the subtitles downloaded, how do I merge them with the vdo files? avi etc?
Old 03-11-2008, 03:39 AM   #9 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
I'll answer..
if you are looking to burn dvd's with subtitles then just use a app like convertxtodvd.
It has options to add subtitles to your dvd. Its a simple headache free application. Note the subtitles wld be optional, you can switch off subtitles using your dvd player remote.
If you just want to play vob/avi files on your PC.
Download and install SMPlayer..,
download subtitles as suggested in above posts.
open vob/avi file in smplayer and open the downloaded subtitles in smplayer, using the subtitles menu.
The great thing abt smplayer in that you open any subtiles from any folder for any file.. and you can easily adjust the subtitles settings like delay/size etc .
So bottom line is get subtitles > open it smplayer to see if it matches your video file > convert (if avi ) and burn along with subtitles to your DVD using ConvertXToDvd .
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Subtitles Nilesh.Ravindran Software Q&A 11 18-12-2009 12:49 PM
help me on subtitles saurabh kakkar QnA (read only) 1 05-01-2008 02:37 PM
subtitles magneticme200 Software Q&A 3 25-07-2007 07:19 PM
How To Put Subtitles In A Movie...??? chahal63 QnA (read only) 5 16-01-2007 01:56 PM
Subtitles Help mako_123 QnA (read only) 3 23-03-2006 01:13 PM
- by gforz
- by soumya
