Originally Posted by ravalon
i recently borrowed a 8gb Transcend pen drive from a friend it was working fine ... then suddenly it says this drive is write protected ... remove write protection or replace disk ... i tried format utility n repair disk .. both say flash drive not found .... HELP!!
Normally for pendrives, there will be a tiny notch kind of lock switch on the body. Look for it.
what is the model number of your pen drive.
YOu have to switch the notch to the other side to disable write protect.
