Old 21-05-2005, 01:10 PM   #1 (permalink)
QA Juggler
saROMan's Avatar
Default Query about registry!!
well as we all know that Whn ever the computer starts the registry is been loaded in RAM for proper funtioning ....in Win2000 ..u can see the Size of registry in the Advance System Config Tab..but there is no Option in XP ....is ther any way i can see the Size of registry ..so that i can reduce its size by cleaning to free UP ram ???
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 21-05-2005, 02:51 PM   #2 (permalink)
HI saROMan,
use regcleaner . this should solve UR pROBLEM!!!!
dOWNLOAD IT FROM HERE IT IS 540 KB in size Download !!!
http://www.worldstart.com/weekly-dow...cleaner4.3.htm
Have FUN !!!
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 21-05-2005, 05:26 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
thx King_Niral ..for link...But i aint lookin for software..i have Them in Kilos......i am looking for precedure to find the size of my registry in XP.......
thx for ur efforts..i appreciate that..
saROMan is offline
Old 21-05-2005, 10:19 PM   #4 (permalink)
ur WELCOME DUDE!!!! OK I TRY A FIND MATTER ON THIS !!!
CYA !!!
take care !!!
CHEERS !!!
Old 22-05-2005, 06:12 AM   #5 (permalink)
expertno.1's Avatar
hey saroman !
backup your registry !
and then see the backup file size !
expertno.1 is offline
Old 22-05-2005, 09:46 AM   #6 (permalink)
Originally Posted by expertno.1
hey saroman !
Try wat he says !!!
Old 25-05-2005, 09:10 AM   #7 (permalink)
Distinguished Member
anandk's Avatar
along with a Registry Cleaner also use a Registry Compactor.
visit www.download.com
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 25-05-2005, 09:30 AM   #8 (permalink)
expertno.1's Avatar
use system mechanic reg cleaner if you have a problem !
Old 25-05-2005, 09:45 AM   #9 (permalink)
QA Juggler
saROMan's Avatar
well this is what i want to know...i was loookin for a soft name which will find the size of registry etc.....also i dont have any problems with registry right now......Currently i have Regfix Pro , TweakNow RegCleaner Pro , TuneUP Utilities Installed on my PC..so there cant b any problems that 4 sure
seems to be a good option..will try it..thx
saROMan is offline
Old 25-05-2005, 09:59 AM   #10 (permalink)
yeah that is a good soulution !!
CHEERS !!!
- by gforz
- by soumya
