Old 30-10-2008, 10:12 AM   #1 (permalink)
cluby's Avatar
Question Lower Power Consumption
I have an ASUS motherboard & AMD X2 4400+ proc.
I want to know how to minimize the power consumption while I am only downloading ( 2-8 ) using any tools or bios settings.
I usually switch off the monitor.
cluby is offline
Old 30-10-2008, 10:42 AM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Lower Power Consumption
well, yes tats obviously advisable..
btw,
if ur display is from a GPU card (graphics card), u can remove the monitor's plug from the graphics card and use the onboard graphics by connecting the pin socket of monitor to tat of the mobo (from the back of the CPU).
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 30-10-2008, 04:39 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Till 2 AM, keep the comp hibernated. I do that and it helps reducing the bill. I sleep at 10 or 11, so 3-4 hours of power save.
dheeraj_kumar is offline
Power Consumption dhanusaud QnA (read only) 4 24-07-2008 09:44 PM
Power Consumption club_pranay Hardware Q&A 14 03-10-2007 03:02 PM
Power consumption of CRT v/s LCD?????? pushkaraj TVs / Monitors 9 19-07-2007 07:54 PM
Power Consumption by my PC?? Manshahia Hardware Q&A 12 16-02-2007 08:51 PM
Less Power Consumption PC? GameAddict QnA (read only) 5 29-09-2004 08:34 PM
- by gforz
- by soumya
