Re: strange problem...
1.) well, its not a s/w problem for sure...but hv u checked the temperatures ?? in bios ??? plz check them and post it here, also note down if there are any abrupt temperature rises..
2.) btw, wat RAM are u having ??? and are they multiple RAMs or jus a single RAM stick (module) ?
3.) if its multiple sticks, make sure they all run on the same frequency..and are all of the same make (manufacturer)
4.) also, remove the cords (power cords) from all the optical drives tat u hv and jus run the PC with HDD connected....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
