Old 28-10-2008, 11:56 AM   #1 (permalink)
Extheist
aditya1987's Avatar
Question Palit HD 4850 Sonic OR XFX 9800 GTX+
Please help me guys,
I want do buy a gfx card which one should i go for?
aditya1987 is offline
Old 28-10-2008, 12:06 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Palit HD 4850 Sonic OR XFX 9800 GTX+
I would go for HD4850. No second thought.
desiibond is offline
Old 28-10-2008, 03:14 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Well ^^^^
But what r ur needs and budget?
Later u'll find out u might just need an HD4830, which wud still be an overkill
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 28-10-2008, 04:09 PM   #4 (permalink)
Extheist
aditya1987's Avatar
My budget is around 12k.
I will use it for playing games at 1440X900.
Old 28-10-2008, 04:21 PM   #5 (permalink)
M3TAL H3AD M3
skippednote's Avatar
+1 HD4850
and CM 650W
I spit Rainbows.
skippednote is offline
Old 28-10-2008, 08:47 PM   #6 (permalink)
toofan's Avatar
Palits HD 4850( may be sonic edition) and a crosair 450
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 30-10-2008, 01:22 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
He already mentioned whether SOnic or 9800GTX+ duh^^
Well, try to fit in the 1GB DDR3 variant, will be useful when u later upgrade the monitor to one wid higher resolution.
About me:
Palit hd 4850 with no crossfire connector ! plzz help!!! Power_user_EX Hardware Q&A 37 29-01-2009 10:57 PM
Q on Palit HD 4850! RMN Hardware Q&A 8 16-10-2008 11:05 PM
Palit 9800gt VS 4850!!! george101 Hardware Q&A 27 28-09-2008 01:26 PM
- by gforz
- by soumya
