Old 20-05-2005, 08:45 PM   #1 (permalink)
Default how 2 run multiple Monitor using one system?
i have one PC with 2.4ghz processor n 512 MB RAM. n 2 VGS cards n 2 monitors. now Iahve to run these 2 monitor using that one PC how can i do n what software i need? n where do i get? plz would u help me? as soon as quik.
Hey I am cool..........
kamaal is offline
Old 20-05-2005, 08:50 PM   #2 (permalink)
expertno.1's Avatar
what do you want to do ?
you want to run monitor and keyboard and mouse for one and this for another ?
that is possible ! (i think you want that to make the pc server of two machine like)
but if not then it will be useless to use two monitors as there will be same thing apear on both the monitors !
what do you wanna do explain a bit more clearly !
expertno.1 is offline
Old 21-05-2005, 12:25 AM   #3 (permalink)
Hi Kamaal
In Win98 you can simply install both the graphics card and in the Display properties you can adjust both the monitors.
anupamsinha is offline
Old 21-05-2005, 01:28 AM   #4 (permalink)
He is rit.. Xplain wat u want to do xactly? i.e use a single comp wid two mouse , keyboard n monitor or only two monitor?
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 21-05-2005, 03:20 AM   #5 (permalink)
144
144's Avatar
What kind of VGA card do you have? Why dont you get an AGP card that Supports Dual Monitor and use the same PC and 2 Monitors..
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 21-05-2005, 07:24 AM   #6 (permalink)
yeah , if u wanna have the same display on all the screens ( u can support 3 monitors on a graphics card , 2 monitors + 1 tv , me using a 29" HDTV right now ) , u must have the required gfx card ( now days , mostly all of them come with that option )
diff displays on diff monitors , now thats a totally a diff issue . if u r going that way , post a reply
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 21-05-2005, 10:37 AM   #7 (permalink)
rohanbee's Avatar
Im very interested in this Different diplay on two monitors.
1.) Can the second monitor be an extension of the First monitors screen
2.) Since i have a HT processor and running multiple programes is not to bad,, can i run different progrmame on a different monitors at the same time.
3.) Cani attach two options. One Crt and the other LCD
Thanks in advance for any kind of input!
Quote by Garfield'
rohanbee is offline
Old 21-05-2005, 10:55 AM   #8 (permalink)
Default support me
I have to run ( monitor + keyboard + mouse) 2 or (more if possible).
kamaal is offline
Old 21-05-2005, 11:01 AM   #9 (permalink)
I have to run ( monitor + keyboard + mouse) 2 or (more if possible), using that one PC how can i do n what software i need? n where do i get?
kamaal is offline
Old 21-05-2005, 11:12 PM   #10 (permalink)
Rebooting
Choto Cheeta's Avatar
well u need a hardware called +ONE PC
its a PCI card which will allow u to do what u want...
visit this site for more details....
www.adlinesystems.com
Choto Cheeta is offline
Old 22-05-2005, 05:21 PM   #11 (permalink)
YEAH TRY THE ABOVE !!!!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 22-05-2005, 10:53 PM   #12 (permalink)
Rebooting
he didnt replyd.... may be that product isnt available in Napal where he comes from....
Old 23-05-2005, 06:54 AM   #13 (permalink)
there was a tut in 1 of the digits , cant remember which 1 . would check up n tell
mamba is offline
Old 23-05-2005, 08:15 AM   #14 (permalink)
expertno.1's Avatar
there is a requirement of hardware for your query
- by gforz
- by soumya
