Old 27-10-2008, 09:08 PM   #1 (permalink)
java is fun.
digitalage's Avatar
Default Compiler design
i was struggling for A program on net that can check the variable declaration in a file for example int, char, etc.
can anyone provide it to me,,,,,
digitalage is offline
Old 27-10-2008, 09:33 PM   #2 (permalink)
Back!
red_devil's Avatar
Default Re: Compiler design
a. you think this is the right section ?
b. you want the program to find out if the variable is an integer or a char or float ?
red_devil is offline
Old 27-10-2008, 10:44 PM   #3 (permalink)
java is fun.
digitalage's Avatar
the program should identify the int, char, float "keywords". i.e. correct syntex in a program.
Old 27-10-2008, 11:59 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Whats wrong with the syntax for a declaration statement? Its
datatype varname1 [, varname2, ...] [arrayindex] [= {value1, value2, ...} ]
I might not understand your question correctly. Give an example...
dheeraj_kumar is offline
Old 28-10-2008, 12:33 AM   #5 (permalink)
harryneopotter's Avatar
he wants to ask for a program that will read a text file and can identify keywords used in it, and verify if they are used correctly.
Hope I am right.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 28-10-2008, 11:36 AM   #6 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
I think he jus wats to findout how many KEYWORDS are there present in a given file..
or maybe, still check if he has written them correctly or no (spelling)..
Well, if u are into JAVA, u can use Netbeans or JCreator,and it will highlight the keywords in a different color that the rest of the programming code..
btw, wrong section..shud be posted in programming section..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 28-10-2008, 11:58 AM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
You wish to check if the declarations are right? Why, that's easy. What language do you want your program in?
Or maybe (just guessing) you are looking for tools like LEX and YACC? You can find those here: http://dinosaur.compilertools.net/
Harsh J
www.harshj.com
QwertyManiac is offline
Old 28-10-2008, 12:12 PM   #8 (permalink)
a_k_s_h_a_y's Avatar
you are trying to create the output of a LEX and YACC. And to that you want to add Syntax corrector algorithm.
Its very tough not a easy job.
Mathematically very challenging.
This is first phase of compiler design, that is lexical analyzer. But not the actual compiler design itself.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 28-10-2008, 09:17 PM   #9 (permalink)
Back!
red_devil's Avatar
i'm still not able to understand what he wants to do !!
Do you want to create a program in which at run time you wanna give a file name as input and you want your original program to find out the data types of variables declared in this input file ??
is that what you want ?
need a c-compiler! direfulsky Chit-Chat 2 30-09-2007 10:52 AM
Help with C compiler.. plsoft Open Source 5 14-04-2006 02:41 PM
C compiler Generic Superhero QnA (read only) 6 12-01-2006 06:22 PM
best c/c++ compiler sonu_mittal1 Programming 2 28-12-2005 11:51 PM
C compiler for XP x64 Netjunkie Software Q&A 1 26-12-2005 12:11 PM
- by gforz
- by soumya
