Old 27-10-2008, 05:45 PM   #1 (permalink)
njs
niharuce's Avatar
Default startup woes
I am using Windows Vista home premium.
I disable the unwanted programs from startup using msconfig. But each time I use Yahoo messenger or encarta dictionary or IDM they add themselves into the list of startup programs.
Is there any way I can disable them?Plz help
niharuce is offline
Old 27-10-2008, 07:05 PM   #2 (permalink)
Default Re: startup woes
Launch each prog seprately and then uncheck or disable the ' run on start up'. This should work.
Aamir_x64 is offline
Old 27-10-2008, 11:53 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ Yep. That should be somewhere in the options box of the program.
But, I'll tell you something even better. Install Spybot SnD, and when you start any program which wants to add itself to the startup list, deny it. From then, spybot will automatically deny the request for you.
dheeraj_kumar is offline
Old 28-10-2008, 11:54 AM   #4 (permalink)
Cool Buddy's Avatar
if you remove the startup from inside the program itself, then it won't start again. however this is not true for any product by apple, they don't have a disable startup option except quicktime.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Startup woes + user accounts rakesh14021983 QnA (read only) 3 10-10-2006 07:09 PM
Win 98 startup disk ! ! ! ax3 Software Q&A 9 23-06-2006 04:15 PM
Startup Only amitgg QnA (read only) 1 01-03-2006 12:01 PM
DOS on Startup Apollo QnA (read only) 5 13-12-2005 12:14 PM
avg startup karthik316_2003 QnA (read only) 8 24-05-2005 10:03 PM
- by gforz
- by soumya
