Old 27-10-2008, 01:08 PM   #1 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Default How to play asf files????????........
I have songs of fifa 2005 in .asf format. How can i play it................????????????????
IronCruz is offline
Old 27-10-2008, 01:17 PM   #2 (permalink)
Default Re: How to play asf files????????........
^^Doesn't it open in Windows Media player?
http://support.microsoft.com/kb/316992 says it is supported by WMP(7-11)
ThinkFree is offline
Old 27-10-2008, 02:15 PM   #3 (permalink)
Cool Buddy's Avatar
try VLC media player. However, it should heve opened in windows media player. Install k lite codec pack.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 27-10-2008, 02:49 PM   #4 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Thumbs down Re: How to play asf files????????........
No it doesn't work i tried
IronCruz is offline
Old 27-10-2008, 02:54 PM   #5 (permalink)
^^Not working even after installing k lite codecs?
Old 27-10-2008, 03:10 PM   #6 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
yahh.....
IronCruz is offline
Old 27-10-2008, 03:25 PM   #7 (permalink)
Cool G5's Avatar
^What about VLC player?? You tried in VLC?
Cool G5 is offline
Old 27-10-2008, 03:44 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
1st look 4 the decoder which will decode the required file format...then install the codec pack with the decoder u found...it shud work...
Zangetsu is offline
Old 27-10-2008, 05:16 PM   #9 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
EA Sports' ASF format is not the same as Microsoft's ASF format.
Get the ASF-MP3 converter called "FIFA Music Changer 2005"
http://fifasoccer.ru/en/files/?info=77
dheeraj_kumar is offline
how to play asf files???s refusing to play mayneu QnA (read only) 4 21-11-2006 09:42 PM
how to play dcr files? ssk_the_gr8 Software Q&A 1 05-10-2006 05:20 PM
*.eye files ?????? how to play them on PC abhasbajpai Mobiles and Tablets 2 07-02-2006 05:37 PM
m1v files ? how to play them? CyCo QnA (read only) 17 22-01-2006 08:19 PM
Can't play *.wmv files. luckyguy QnA (read only) 6 03-09-2004 02:28 PM
- by gforz
- by soumya
