Old 20-05-2005, 03:44 PM   #1 (permalink)
Default telnet & socket prog..
I tried to telnet my system i.e, 127.0.0.1 both in linux as well as windows but all I get is 'connection refused'. why is this so?
Also I created a srever program that binds itself over a port so as to respond to users connecting on that port in my linux box. But when I use $netcat 127.0.0.1 , I get 'connection refued' again here . Why do u think this is happ... .
sridhar8310 is offline
Old 20-05-2005, 04:03 PM   #2 (permalink)
is ur telnet port up and running?
i mean check ur ip with a port scanner to see if port 21, 23 open?
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 20-05-2005, 05:58 PM   #3 (permalink)
how do I do that, I don't have any port scanners. and if the port is closed, how do I open it.....
Old 20-05-2005, 06:38 PM   #4 (permalink)
Are you sure there is no firewall running on your pc ......
keen is offline
Old 20-05-2005, 11:32 PM   #5 (permalink)
LOL some weird replies in here.
First of all all the ports are open by default unless you purposefully close them by using some sort of a firewall on a windows machine.
EDIT:
Duder port 21 is the default port for FTP[File Transfer Protocol].
From what I get from the post you are trying to connect to as in a client/server model?
Assign a IP address to the machine & specify a port say for a web server port 80 which is the default port.
Try accessing the same from a different machine by specifying the IP address & the port specified.
This should work if thats what you are looking for.
www.Oobertech.net
digen is offline
- by gforz
- by soumya
