Old 20-05-2005, 02:50 PM   #1 (permalink)
Default INSTALLING FROM IMAGES
I had downloaded a lot of games and softwares which are split into 2-3 images. When I install them, the setup asks me to put the 2nd CD, but where!!!....it didnt ask me to specify location of contents of the 2nd CD....then i realised that I will have to burn them on CD's and then install them...however is there anyway I can get away with this??
sahil_blues is offline
Old 20-05-2005, 03:03 PM   #2 (permalink)
Well i think u are using Pirated version!
right
Becoz..............this happens when u use pirated version!!!!!!!!!
abhinav is offline
Old 20-05-2005, 03:06 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
What you need is a proggie called Daemon Tools, it emulates the iso images as a CD drive and helps you continue with your installation
just install the software and select the path of the image file from the system tray
Get Daemon Tools from here
Sourabh is offline
Old 20-05-2005, 03:09 PM   #4 (permalink)
right
there is nothing pirated about it....amongst the things I downloaded, few asked me to specify the location of the contents of the 2nd CD (i had all the contents of both the cd's extracted on my hard disk)....and their installation went without any other hiccups....
Old 20-05-2005, 09:17 PM   #5 (permalink)
expertno.1's Avatar
oh folow this :-
install hackman and use its join function to join the images and run using Daemon tools or extarct the files from the images and then create a new image of all the files and put it into Daemon tools
expertno.1 is offline
Old 21-05-2005, 01:39 AM   #6 (permalink)
Biplav's Avatar
ok i downloaded nfsug and its a 736mb download.
i used isobuster to extract the bin file(yah the downloaded file was a bin file)and it contained 1 iso and the other was not an iso.
i extracted it to my harddrive. when i install it, after nearly 80%it says to insert 2nd disk now i had used nero 5.5 and created a .nrg image and put the 2nd disk into virtual drive, but it still asks 4 2nd disk.
now when i cancelled this.
now when i open the 2nd disk , it tells me to insert 1st disk, even after doing that it again asks to insert 1st disk,
help
i hope it wasnt very confusing!
Biplav is offline
Old 21-05-2005, 03:26 AM   #7 (permalink)
144
144's Avatar
Try using an emulator. You can use Alcohol 120% trial version. If you want a freeware google for one.
Just mount your second CD (right click image and click mount) -- and the virtual drive created by alcohol or anyother emulator will load it.. And you can continue ur installation.
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 21-05-2005, 07:37 AM   #8 (permalink)
QA Juggler
saROMan's Avatar
well if u have a bin fine..then its really easy...install Alcohol 120% ...right click and click on add image..browse where ur Bin file is saved.....when u see the image file in the Alcohol window..just right click and mount on virtual drive....Volla.....u can now use it as a CD ...install/Burn do what ever u want.....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 21-05-2005, 10:30 PM   #9 (permalink)
Biplav's Avatar
thanx saroman.
but after going to near about 60% it tells me to insert 2nd cd?
now my file is 736 mb and i dont think 1 cd can contain that much.
so why is he askin me to insert 2nd cd?
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 21-05-2005, 10:52 PM   #10 (permalink)
Hey Biplav, I too heard the issue with NFS-UG from my friend. he to has the same issue where its asks the 2nd CD and then the 1st. and never
takes/detects them. donno why. tried all possible ways. nogo.
RajŪ Anyone else is not me...!!!
rajas is offline
Old 21-05-2005, 11:00 PM   #11 (permalink)
Biplav's Avatar
now plz some one tell me i didnt waste 2 days downloading nearly 800 mb 4 nothing!
Biplav is offline
Old 21-05-2005, 11:38 PM   #12 (permalink)
what do you mean exactly???.....NFS Underground is split into 2 CD's.....each of size 700-750MB....I know that because i wanted to downloaded NFSU 2 but the file i actually downloaded was NFSU 1 which I already had!!! it cant be worse than that!!!
Old 21-05-2005, 11:59 PM   #13 (permalink)
Biplav's Avatar
same here sahil bluez
i downloaded nfsug2 but the downloaded file was ug1
anyways i was a bit lucky as i didnt have the full versions of any of the two. so it will do.
ok now i will download the cd2 and lets see wat happens.
Biplav is offline
Old 22-05-2005, 08:31 AM   #14 (permalink)
Biplav's Avatar
OK! its working . I had to just download another nfsug2.cd2!!
Biplav is offline
Old 22-05-2005, 02:57 PM   #15 (permalink)
thax a lot sourab for that link...i downloaded Daemon tools....i really love it....its so simple and effective!!!...
Old 22-05-2005, 04:15 PM   #16 (permalink)
Biplav's Avatar
@sahil bluez try alcohol 120. its just gr8. no need 4 anything. just click on the bin file and mount it. as simple as that!
Biplav is offline
Old 22-05-2005, 06:38 PM   #17 (permalink)
man i once tried alcohol 120%....it screwed my dvd drive....the drive wasnt playing anything.....then i had to uninstall alcohol and reinstall the drivers.....thats why iam a bit scared to try it again....
Old 22-05-2005, 07:09 PM   #18 (permalink)
Biplav's Avatar
oh! may be there must have been something wrong. but i have tried it and used it and it does not give any problem.and yes it is highly rated.
Biplav is offline
Old 22-05-2005, 07:33 PM   #19 (permalink)
Laptoping
Sourabh's Avatar
Personally i hate alcohol 120%
I use these three progies for diff purposes
1. Clone CD ...for easy, fast and non resource hogging copying of cds
2. Nero for all its different options .. burning in diff formats, bootable cds and stuff
3. Daemon Tools to manage all the isos on my hdd
Sourabh is offline
Old 24-05-2005, 09:12 PM   #20 (permalink)
Biplav's Avatar
@saurabh- my nero couldnt open .bin files.
so i just though of giving alcohol 120 a try.to my surprise i found it to be the simplest.all u have to do is just mount the image on the virtual drive(that takes 5-10 seconds to go to the direscotry and 2 seconds to right click and then select mount.)so in my opinion it is the fastest too.doesnot have features like nero but does the purpose as simple and as fast as it can get...
Biplav is offline
- by gforz
- by soumya
