Old 20-05-2005, 05:15 AM   #1 (permalink)
Stabbing my shoe
Default Regarding saving updates after SP2.. Urgent ! !
Hi!
I would like to know that how do I save all my updates installed after SP2.. I have read many posts regarding this topic on the forum but did not get a satisfactory answer regarding saving all the updates after SP2. So,please help me by answering the following:
Which folder exactly will I have to save?
When I have reinstalled my system with SP2, how do I reinstall those updates on to my PC?
Does the AutoPatcher which comes on the DIGIT DVD have any use in updating my PC if I do not save the folder in which updates after SP2 are there?
Plz reply.. THANX
Warm regards, Siddhartha
>> Siddhartha <<
> http://sidroy.wordpress.com <
> Beauty lies in the eyes of the Beer Holder <
//siddhartha// is offline
Old 20-05-2005, 07:18 AM   #2 (permalink)
sidewinder's Avatar
look for a hidden folder MSdownload.tmp.It could be anywhere depending upon the available partitions in ur hdd.But most of them will not work if u try to install them manualy.KB hotfix updates can be saved nd installed later this way
Bombina rocks
sidewinder is offline
Old 20-05-2005, 03:43 PM   #3 (permalink)
Default here
%SYSTEMFOLDER%\SoftwareDistribution\Download is the folder u r looking for buddy..
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 20-05-2005, 06:25 PM   #4 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
See my post regarding this on
http://www.thinkdigit.com/forum/view...=2258&start=60
navjotjsingh is offline
Old 21-05-2005, 11:58 AM   #5 (permalink)
QA Juggler
saROMan's Avatar
Default Re: Regarding saving updates after SP2.. Urgent ! !
Originally Posted by //siddhartha//
Hi!
Plz reply.. THANX
->%SYSTEMFOLDER%\SoftwareDistribution\Download
OR
c:\Program Files\WindowsUpdate
These are Hidden folders so u have to go to folder option uncheck Hidden/system files etc
Just Double Click Each File and it will get Installed ..Only drawback is you will have to Restart every time....
The Best way is get autopatcher ......
Yes if u have Autopatcher ..you dont ned to save the Updates(Though u will need to save new Updates installed after Autopatcher is installed )
Autopatcher has all the Updates available till the date of its release ..also it restarts only 1's in the End ....
CONCLUSION
Install Sp2 ...Install the Latest Autopatcher ver you have ..and you have a Nearly Uptodate System (if ur Autopatcher is lill bit older)
8-) सारोमान :!: :!: :!:
saROMan is offline
- by gforz
- by soumya
