Dude dont be lazy just have a look at the Installtion segment of the source article
here
It very well works, if configured properly i may mess up wid ur drive letters and when u try to uninstall the proggie it wod further cause BSOD's
Make sure u read the document carefully before applying
Also there are no issue with it coz its read only
even if u move or copy a file on the NTFS drive it would just show tht its transferred but in reality when u check it through WIndows XP , the file is not there
So try deleting all the contents of the NTFS drive from win 98 ....hehehe
