Old 20-05-2005, 12:39 AM   #1 (permalink)
Extheist
aditya1987's Avatar
Default Help me buying new PC
Hi Guys I am going to buy a new pc. I am a hardcore gamer. Can you tell which configuration should I have. I would perfer AMD with DDRII ram. My budget is around Rs50000. Thank you.
aditya1987 is offline
Old 20-05-2005, 12:53 AM   #2 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
you should try AMD Athlon64 3500+ based confugeration, with Asus nforce4 Board...
rollcage is offline
Old 20-05-2005, 01:18 AM   #3 (permalink)
man this will rock
AMD 64 3000+ (939) 7850
Msi Diamond SLi- 12200
1Gbx2 Zion 400 Ram 10800
Sony Dvd RW 5000
Samsung 160 Gb Sata 4000
I Box With 400 W (vip/Powersafe) Smps 2000
17" Flat Crt Samsung 7300
5.1 Creative 5000
Nvidia 6600GT 13000
total 67500(approx u can get tem a price lower than them)
Happy Computing :lol:
krishnathelord is offline
Old 20-05-2005, 09:28 AM   #4 (permalink)
btw ddr2 is not present on amd boards.........and ddr is better than ddr2(ddr2 doesnt provide any significance change than ddr).....
also if u go with kris config....add 1-2k mor and get ard 500w smps.....hardcore gamer plays always on high settings and all......i doubt abt samsung hdd........how is seagate 160gb sats btw????ram is okk so i card...also check acer moniter first.... i heard in the forum they r good
magnet is offline
Old 20-05-2005, 09:31 AM   #5 (permalink)
ya one mor thing is it true...nforce 4 cards doesnt support win 98 and me editions??????...on msi site on mobos using the chips its mentioned.......alsoin amd 64 category which is the last series....3800+???? or something else..and wht significance it provides over 3200+ and all
magnet is offline
Old 20-05-2005, 10:05 AM   #6 (permalink)
If you really want a config try this one,nobody here has given a total decent system
Firstly it would be better to raise the budget a much as you an espeially till about 75k if not more.
I have bought my computer parts for above 63k.
Do you want speakers etc also?
Amd 3000 64 939 winchester (90nano meter technology),maybe 7500
Asus A8N-E,no sli,i bought for 9400 in delhi but in mumbai you might find for abt 8500 and might less
8500
RAM
corsair 2 X 512mb ddr 400 cl=2.5 for 5824 in delhi
hynix 2 X 512mb ddr 400 you may get for 2200-2400 per piece
so,4800-5824
160gb seagate sata ncq i bought in delih for 4150
for better sound you shd go with sound card but your budget most likely doesn't permit this
do you need cd-rw?
anyways,
liteon dvd rom,i bought for 1500 though you may find it cheaper,i bought black
black cd-rw,asus ,i didn't find asus so took black benq for 1350
your budget won't allow antec so you may take zebtronics or something,if possible go with antec 400smart power or higher,shd be abt 3-3.5k
neways if possible consider 450 or higher,ask others abt 350,why take chances thoguh?
zebtronics cabinet atx + 400 watts ps or higher,look at power rating,amperes first and only if they asre good ,buy,
1.5-2k
if possible go for 450 watts or higher
sony fdd for 275 or higher
samsung 793mb (17")- i bought for 7100 from smc international in nehru place in delhi
128mb geforce 6600gt pci-e or higher ,i bought xfx for 10300 thoguh you may get in delhi for 10.5 also
also consider leadtek though it is probably better it may come with 1 yr warranty and may not be easily available everywhere,so if you need to rma and get in hassels...
to the point leadtek may be for 9850+tax etc
leadtek you can ask zebroncis abt it
leadtek box clocked may be for 10700,may be before tax though
10500
altec lansing 251 60watts rms for abt 5k
i bought with 45watts mrs for 3850
microsfot internet kb-black preferably if you like,ask for other kb to others
microsoft ms optical wheel mouse,if you don't find it then microsoft basic optical wheelmouse not as good though
or logitech mx 310
first and third are better than middle
akshayt is offline
Old 20-05-2005, 10:32 AM   #7 (permalink)
rohanbee's Avatar
Not bad akshayt ! i dont know if this was helpfull to the person who started this thred but it definately helped me. Thanks
Quote by Garfield'
rohanbee is offline
Old 20-05-2005, 07:44 PM   #8 (permalink)
if your a hardcore gamer than take a 480 watts true blue true power antec powersupply...
its for aorund 5600 at lamington road..
the reason is as magent stated it..
that hardcore gamers always like to play at high settings. and all this does put strain on the powersupply...
antec true blue true power 480 watts - 5600
hmm... you can also go for this rig..
asus a8n-sli deluxe - 12100
amd 64 3000+ 7700
transcend 2*256 mb ddr pc3200 ram - 4k . approx
xfx 6600 gt - 9.5k
creative inspire 5.1 - 4800
antec lanboy case - 5300
logitech keyboard + mouse = 1000
160 gb samsung sata - 4300..
totals to ---> 54300..
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 20-05-2005, 07:47 PM   #9 (permalink)
forgot the monitor for 6k.. samsung... so the total budget will be 60k...
the best thing to do would be to go and inquire in shops in your area.. and tell here whats avaialalbe. and what`s not.. which will help you decide better..
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 22-05-2005, 09:06 PM   #10 (permalink)
samsung 793mb for 7100
why sli?
asus a8n-e with amd 3200 winnie for abt 9500,a8n-e might be better ocer
also,i bought sl450 antec for 4100,25amperes on +12va line
i bought 150seagate ncq sata for 4150
just refer to what i bought in other posts
akshayt is offline
- by gforz
- by soumya
